Targeted spraying maps for XAG drones with PIX4Dfields
The following article describes how to export boundary missions and targeted spraying maps created with the PIX4Dfields Targeted Operation feature for XAG spraying drones.
本記事では
Types of missions supported by XAG spraying drones
Create a boundary mission
Create a VRA mission
Export and upload missions into the XAG platform
Prepare a mission in the XAG One app and fly!
Types of missions supported by XAG drones
XAG's spraying drones support two types of missions:
- XAG boundary mission
- It allows the definition of the field area to be sprayed along with obstacles and no-spraying zones. It only supports one fixed rate.
- Compatible models: all models.
- Exported file: KML.
- XAG VRA mission
- It allows a variable rate to be applied to the field area to be sprayed, along with obstacle and no-spraying zones. It supports up to three different application rates.
- Compatible models: P150, P100H 2022, P100H Pro 2023, V50H 2023.
- Exported files: KML and JSON.
Create a Boundary mission
A boundary mission can be exported in two ways:- If obstacles and no-spraying areas need to be defined, a targeted operation must be created.
- Mark the boundaries, obstacles and holes to be used in the operation.
- Create a Targeted Operation. select Do not pre-fill grid cells and use the Fill option to assign a rate to all the operation.
- The mission is ready to be exported.
Make sure that the area to be applied has a rate assigned, if they are set to 0 L/ha, the whole field will be treated as a no-spraying area.
2. If obstacles and no-spraying areas are not to be marked, simply export annotations or boundaries in KML format and upload them to XAG.
A variable rate application map is created using the Targeted Operation feature.
In this example, weeds were detected using the Magic Tool, and a VRA mission was generated directly within the tool
- Start the Magic Tool and detect the infested areas.
- On the 6th Step, select convert to Operation.
- The Operation is created.
- Two rates were assigned according to the severity of the infestation.
- The Operation is ready to be exported. Variable rate operations are limited to a maximum area of 33 hectares.
The Operation will be downsampled to 5 5-meter grid.
Export and upload missions into the XAG platform.
Export missions
When missions are ready to be exported:
- Go to Export, Operations.
- Select the Operation to be exported.
- Select Operation for XAG:
- Select XAG Boundary mission or XAG VRA mission.
- Click Continue.
- Select what to do with the hole inside the boundary
- If treated as Obstacles, the drone will not fly over these areas.
- If treated as No-spray areas, the drone will fly over without spraying.
- Click Export.
Warnings
- "This export format only supports areas up to 33 ha."
Variable rate operations are limited to a maximum area of 33 hectares. If an attempt is made to export a field larger than this size, the error message will pop up. Solution: Split or reduce the size within the Operation. - "Each boundary or each subpolygon of a MultiPolygon will result in an individual field upon import to the XAG One platform."
Operations that contain more than one boundary will generate a flight per boundary.
Errors
- "This export format supports a maximum of 3 rates."
VRA maps are limited to 3 rates. Solution: Remove a rate from the Operation. - "XAG VRA missions do not support multiple boundaries or MultiPolygon boundaries"
Solution: Ensure only one boundary per Operation.
Upload to XAG ONE Management Platform
After exporting the Operation map:
- Log in to the XAG FMS platform:
- If in the US: nf-us.xa.com.
- If outside the US: https://nf.xa.com.
- Select if Individual or Organization.
- Go to the Import tab:
- To import Boundaries, select Field Import:
- Click Upload, and select the ".kml" boundary file.
- Once uploaded, click Import app to synchronize to the XAG ONE App.
- If doing a VRA mission, after importing the boundary:
- Select Import prescription map.
- Click Upload and select the JSON file.
- When the Prescription is imported, click Import App to synchronize to the XAG ONE App.
- Select to assign it to an Individual or a Team.
- Click Ok.
The app version must be V5.8 or above to use the VRA function.
To see the Boundary mission and the VRA mission:
- Log in to the XAG One app.
- Go to the top-left icon and find the imported field:
- When doing a VRA application, change the Spraying settings.
- Click Default
- Select the Prescription map
- Click Start Operation
- The following videos show how to access the prescription in the XAG One app and set the operation before the flight:
Safe flights!
