Failed to stitch images - R0010 - PIX4Dreact
This article contains the main causes that generate Error R0010 while processing a project.
本記事では
Error
Description and causes
Not enough images
Not enough overlap
Problem with the EXIF tag of the images
Folder containing images not selected properly
Corrupted installations
GPU acceleration not supported
Different types of images imported
Contact support
Error
"Failed to stitch images. R0010: An error occurred while stitching the images."
The error occurs after images are imported, and the processing has started. There are several reasons why this error can happen:
Not enough images
The minimum number of images to generate an orthomosaic in PIX4Dreact is three, if fewer are imported, PIX4Dreact will fail to process.
Not enough overlap
The overlap between images is not enough for PIX4Dreact to find matches. PIX4Dreact recommended side and frontal overlap is 80%.
Sometimes the EXIF tags of the images are not correct, and this causes PIX4Dreact to fail when processing. On some occasions, images have incomplete coordinates in the EXIF of the images. If images are located in a different place on earth, this is typically the problem. The images with faulty GPS coordinates should not be selected for processing.
When selecting the Folder containing the images to be processed, it has to be double-clicked. Otherwise, all the images in the above folder will be imported, which will cause PIX4Dreact to fail when processing.
After installing a new PIX4Dreact version, some libraries can be missing, which will cause PIX4Dreact to fail during processing.
There is no need to uninstall the program, the projects will not be lost:
- Download the installer from: https://account.pix4d.com/download-software.
- Double-click on the installer.
- Click Next.
- Select Repair and click Next.
- Click Repair.
GPU acceleration is not supported
Out-of-date GPU drivers can cause PIX4Dreact to fail while processing, artifacts may look like this:
- To update the GPU driver, look up the latest model-specific version available: How to update graphic card drivers - PIX4Dfields. The same applies to PIX4Dreact.
- If updating the driver does not work, process the imagery again, disabling GPU acceleration from the Processing options - PIX4Dreact.
- For more information: Stitching artifacts - PIX4Dreact.
Different camera images
PIX4Dreact can process images from one camera at a time, for cases with two-camera images, they have to be processed separately.
Contact support
If the error is still happening, contact support with a valid PIX4Dreact license. Please share the Log Files and a description of the flight plan, type of images, etc.
