  • 検索フィールドが空のため、提案はありません。
Contour lines - PIX4Dmatic
The contour lines feature connects points of the same height with a polyline. Height values are extracted from a TIN (Triangular Irregular Network) or a DTM (Digital Terrain Model). This feature is also used to generate major and minor contour lines, which are visible in the images.
Note: To generate contour lines TIN or DTM needs to be generated in the project.
Captura de pantalla 2026-01-29 154220
The following settings can be adjusted:
  • Interval [units]: Defines the contour line elevation interval. It can be in meters or in imperial according to the coordinate system used:
    • 1 m - default.
    • 3 ft(US) - default.
contour lines
Tip: The minimum interval value supported is 0.1. Values below this threshold are not valid and will not be accepted.
  • Discard contour loops shorter than [units]: Detects and discards contour lines with shorter length. It can be in meters or in imperial according to the coordinate system used:
    • 10 m - default.
    • 30 ft(US) - default.
