  • 検索フィールドが空のため、提案はありません。
Can't start processing - PIX4Dfields
This article explains the reasons and solutions for not being able to start processing after importing the images.
After importing the images, nothing happens, and it does not start processing.
 Bug
The Start processing button is greyed out, it is impossible to start processing.
Solution
This is related to a broken XML in PIX4Dfields. Remove the XML from PIX4Dfields:
If the XML file is still causing trouble:
  • Ensure the provided XML has the correct format:Correct_XML_
  • Ensure there are no empty tags:Wrong_XML_
  • Ensure there are no incomplete tags like <rigs/> at the beginning or <mappings/> at the end.
