Camera not officially supported - R01120 - PIX4Dreact
Error message
When attempting to process images from a camera not listed in the official PIX4Dreact database, the following error message will appear:
"Camera not officially supported
R01120: This camera is not officially supported, please double check the results carefully. Large location errors are possible."
If significant location errors, visual artifacts, or misaligned maps are present, please refer to: Troubleshooting
Description
When a camera is not included in the officially supported camera database, PIX4Dreact utilizes the embedded EXIF metadata in the images to determine the sensor characteristics. It specifically examines the following tags to accurately identify and estimate the sensor information:
Basic information for camera model assignment
Either:Exif.Photo.FocalPlaneResolutionUnit and either Exif.Photo.FocalPlaneXResolution or Exif.Photo.FocalPlaneYResolution
Or:Exif.Photo.FocalLength そして Exif.Photo.FocalLengthIn35mmFilm
Find the rest of the required tags in this article (e.g., Geolocation information): EXIF and XMP tag information for project creation
As long as the required tags are present, PIX4Dreact is generally capable of producing accurate outputs.
トラブルシューティング
If significant location errors, visual artifacts, or misaligned maps are present, please:- Read: Stitching artifacts - PIX4Dreact, many artifacts are related to the graphics card driver issue.
- Try the XML workflow provided in: Your camera is not supported - PIX4Dreact.
- If issues persist, please contact Technical Support, and provide a detailed explanation of the issue along with the drone images.
