Using GCPs and MTPs from PIX4Dcatch in PIX4Dmatic
This article discusses how to export GCPs and MTPs from PIX4Dcatch and import them into PIX4Dmatic for processing
Ground control points (GCPs) are reference points with known coordinates, typically measured using RTK/PPK GNSS receivers or total stations. In PIX4Dcatch, GCPs can be created manually or automatically with the use of Autotags. To use GCPs in PIX4Dmatic, both the image marks and the corresponding point coordinates must be exported and imported.
Manual tie points (MTPs) are 3D features marked in images that help improve the quality and accuracy of the reconstruction. In PIX4Dcatch, MTPs are generated automatically using Autotags. Unlike GCPs, only the image marks are required since coordinate data is not needed for import into PIX4Dmatic.
Export from PIX4Dcatch
Import from PIX4Dcatch
Import GCP Image Marks
Import Tie Point Marks
Process the Project in PIX4Dmatic Standard / PIX4Dmatic Pro
Exporting automatic GCPs using Autotags
GCPs require the image marks and the point collection to be transferred from PIX4Dcatch to PIX4Dmatic.
- Open the Projects tab and select a project with GCP Autotags.
- Tap the Export
icon. - Select Export Points & Marks.
- Choose the export method (e.g., email, cloud storage).
- marks-PIX4Dmatic.csv
- name_of_point_collection-PIX4Dmatic.csv
Import into PIX4Dmatic
Import GCP Coordinates
- Open the Tie Points tab from the control panel in PIX4Dmatic.
- Drag and drop “name_of_point_collection-PIX4Dmatic.csv” into the window or select it manually.
- Set the column format to PENZ (point, easting, northing, elevation).
- Review the preview table and click Apply.
- GCPs will appear in the Tie Points tab.
- Set the proper coordinate reference system by clicking the
pencil icon.
Note: GCP coordinates must be imported before importing marks.
- In the Tie Points tab, click the
more options icon. - Select Import Marks.
- Choose the file "marks-PIX4Dmatic.csv".
- The table will update with the mark positions.
MTPs only need the image marks imported and do not require a point collection file.
- Choose the file “catchTagsMarks.csv.”
- Tie points will be added and automatically classified as MTPs.
