Transfer Outputs to ArcGIS Online - PIX4Dcloud Pro
This article explains how to transfer outputs generated in PIX4Dcloud Pro to Esri ArcGIS Online. It describes which outputs are supported, how to connect a PIX4Dcloud account to ArcGIS Online, how to transfer data from a dataset, and how to disconnect the integration.
Licenses: This article is only valid for PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can transfer outputs from a dataset in PIX4Dcloud.
Warning:
  •  Esri credentials are required to transfer files. Free public ArcGIS Online accounts are not supported. Only paid ArcGIS Online accounts are compatible.
  •  Important Integration Compatibility: Please note that the PIX4Dcloud integration currently supports ArcGIS Online only. ArcGIS Enterprise (on-premises or custom private cloud deployments) is not supported for now.
Outputs and formats that can be transferred
  • Outputs
    • Orthomosaic: .tiff
    • DSM: .tiff
    • Point cloud: .slpk
    • 3D mesh: .slpk
    Reports
    • Quality report: .pdf
Connect to ArcGIS from PIX4Dcloud
To connect PIX4Dcloud to ArcGIS Online:
  1. Log in with PIX4D credentials at cloud.pix4d.com.
  2. In PIX4Dcloud Drive, click the user icon in the top-right corner.
  3. Click Integrations.
  4. Under 3rd party integrations > Esri integration, click Connect.
  5. On the Esri login page, enter the ArcGIS credentials and sign in.
    1. ArcGIS_connect
  6. After successful authentication, the Integrations page confirms the connection to ArcGIS.
    1. Integration_boton_user_icon
  7. Return to PIX4Dcloud Drive, click the user icon, and verify that the account is connected.
Information: Once established, the ArcGIS connection remains valid for 14 days from the last transfer action. After this inactivity period, the connection must be re-established.
Transfer outputs from a dataset to ArcGIS Online
To transfer outputs to ArcGIS Online:
  1. Open the desired dataset in PIX4Dcloud.
  2. On the top bar, click Transfer.
  3. In the Export dialog, select the outputs to transfer to ArcGIS Online.
    The number of selected files is displayed.
  4. Click # Transfers, where the number corresponds to the selected outputs.
    1. Transfer_output_select_arcgis
  5. Select the destination folder in ArcGIS.
    1. Transfer_popup
  6. Click Send to start the transfer.
The transfer duration depends on the number and size of the selected files.
Information:  For 3D mesh outputs, the .slpk file can be exported as a georeferenced dataset using the Web Mercator coordinate system (WKID: 3857) with EGM2008 vertical reference (WKID: 3855). This configuration is optimized for seamless visualization in ArcGIS Online Scene, particularly when used with Esri basemaps.
2026-02-10_17-46-51
Note: If both ArcGIS and Trimble integrations are connected, outputs from the same dataset can be transferred to either platform. Use the Transfer switcher to select the destination platform.
transfer_switcher
Disconnect from ArcGIS Online
To disconnect the ArcGIS Online integration:
  1. Log in at cloud.pix4d.com.
  2. In PIX4Dcloud Drive, click the user icon.
  4. Select Disconnect under the Esri integration.
Transfer file size limitations
Transfers exceeding the following limits may not be supported:
  • Point cloud (.slpk): 4 GB
  • DSM (.tiff): 1.7 GB
  • Orthomosaic (.tiff): 4.7 GB
