Quality Control in PIX4Dcatch
The Quality Report feature allows users to assess the quality of a capture immediately after acquisition and before saving the project. This enables in-field evaluation of data quality and the option to redo a capture if needed, eliminating the need to return to the office to review results.
How it works
After completing a capture, a summary screen appears displaying:
- The Dataset name
- Two tabs: 3D and Report
- The Save and Continue Scanning buttons
3D view
The 3D View tab displays all captured images along with their corresponding RTK/GPS measurement points.
If the project was captured using an RTK device, the following accuracy indicators are shown:
Low: >6 cm
Reduced: 3-6 cm
Optimal: < 3 cm
Note: The thresholds vary depending on the GPS or RTK device.
Additional tools available in this view:
- Zoom icon
: Centers the 3D model on the screen. - Layers icon
: Expand to modify the point cloud and image layers.
Report
The Report tab summarizes the quality of the capture based on several parameters. Each section provides key metrics and, where applicable, improvement tips.
.png?width=250&height=500&name=Plantilla%20Iphone%20(21).png)
Images
Displays the total number of images and the percentage of images with optimal quality.
Tips for improving image quality are shown at the bottom of the section.
.png?width=250&height=268&name=Frame%20(1).png)
Geolocation
Shows the geolocation source used during capture:
NO LOCATION: No geolocation information was acquired for the images.
GPS: The images were captured using the device’s integrated GPS receiver, providing low positional accuracy.
RTK: The images were captured using an RTK receiver, providing high positional accuracy.
When working with RTK accuracy, the parameters are divided into two subcategories: Optimal accuracies and Consecutive bad accuracies.
Optimal accuracies are split into three ranges:
optimal 90-100%
reduced 50-90%
low 0-50%
Consecutive bad accuracies are split into two ranges:
Optimal 0-50 accuracy samples
Reduced +50 accuracy samples.png?width=250&height=340&name=Frame%20(2).png)
Autotags
Displays the number of Autotags detected, the number of GCPs (if applicable), and how many were successfully recognized.
A green check indicates all GCPs were recognized.
A red icon indicates that some GCPs were not recognized.
.png?width=250&height=258&name=Frame%202608747%20(3).png)
Annotations
Indicates the number of annotations.
Saving the Project
If all parameters meet the project's quality requirements, tap Save to save the project.
If the parameters do not meet the requirements, you can return to continue capturing the project by tapping Continue Scanning .
To discard the scan, tap the Trashcan.
