Process in PIX4Dcloud - PIX4Dmatic
Projects can be uploaded from PIX4Dmatic to PIX4Dcloud for cloud-based processing. Inputs such as images, tie points, and ROI are supported. PIX4Dcloud generates outputs including the Point Cloud, Mesh, DSM, and Orthomosaic.
Process in PIX4Dcloud requirements
How to use Process in PIX4Dcloud
What to expect next
FAQ
This feature is available for PIX4Dmatic version 1.73.0 or later. The following conditions must be met:
- A valid PIX4Dmatic license (trial, monthly, yearly, or One-Time Charge (OTC) license).
- An active PIX4Dcloud subscription with sufficient credits.
- The number of projects that can be uploaded depends on the available credits.
- The Storage expiration policy for PIX4Dcloud applies.
To access Process in PIX4Dcloud, navigate to File > PIX4Dcloud > Process in PIX4Dcloud... or click direclty on PIX4Dcloud button![]()
The Process in PIX4Dcloud window will pop up.
The available Processing templates, Inputs, and Outputs are displayed in this window and explained in the table below:
| Destination |
| Processing template |
| Flat terrain |
| Inputs (available only if the project contains the respective input) |
| Outputs (available only if the project contains the respective input) |
Note: Gaussian splatting is available for PIX4Dcatch projects and drone datasets when they are processed in PIX4Dcloud. At this time, Gaussian splatting cannot be processed in PIX4Dmatic.
After selecting the desired option in the Process in PIX4Dcloud window, click on Process to start processing.
Note: The settings chosen in the PIX4Dmatic project will not be used when processing the project in PIX4Dcloud. PIX4Dcloud will use its own settings depending on the dataset.
Note: If the project contains both types of dataset (aerial and terrestrial), a warning message will appear at the bottom of the 'Processing in PIX4Dcloud' menu advising that processing mixed datasets is not officially supported by PIX4Dcloud.
PIX4Dcloud will apply a processing template based on the first image to reach the platform.
Note: if the project only contains one type of dataset (aerial or terrestrial):
- PIX4Dcloud does not allow applying the PIX4Dcatch template to a drone dataset, only the template Nadir or Oblique can be selected.
- PIX4Dcatch datasets can only be processed with the PIX4Dcatch template on PIX4Dcloud
What to expect next
Once processing begins, the following actions will occur:
- The Status bar in PIX4Dmatic will update automatically with the project's upload status at the bottom left.
- After the upload is complete and processing starts, a first email notification will be sent to the email associated with your PIX4D account.
- Upon completion of processing, a second email notification will be sent.
- The processed results can be viewed directly in the PIX4Dcloud by navigating to File > PIX4Dcloud > View project in PIX4Dcloud in PIX4Dmatic.
- The project can be edited and modified just like a regular PIX4Dcloud project.
Important:
- Ground Control Points, Checkpoints, and Manual Tie Points are available in the PIX4Dcloud's Quality Report.
- Only Ground Control Points and Checkpoints are displayed in the PIX4Dcloud viewer.
FAQ
What will happen if I have insufficient credits?
- When credits are insufficient to complete the processing in PIX4Dcloud, the upload will fail, and a red warning will be displayed in the Status Bar of PIX4Dmatic. Additionally, selecting View project in PIX4cloud will lead to an error page in PIX4Dcloud.
- The project will be uploaded but remain in a Waiting for credits state. The project will be visible in PIX4Dcloud, the processing will start automatically when sufficient credits are added.
I have not yet migrated to the credit system for PIX4Dcloud, can I use Process in PIX4Dcloud?
For users on the credit system:
- There is no limit on the number of projects that can be uploaded.
- For users not yet migrated to the credit system, there are certain limitations:
- PIX4Dmatic monthly billing subscribers can create 1 project per month.
- PIX4Dmatic yearly billing subscribers and OTC license users with active S&U can create up to 12 projects per year.
- PIX4Dmatic trial license holders can create 1 project during the trial period.
Does it create a new project every time I click on Process in PIX4Dcloud?
- Yes, each time the Process in PIX4Dcloud is selected, a new project is created in the PIX4Dcloud account. Credits are consumed accordingly every time a new process is completed. This also means that the same project can be processed multiple times with different inputs and outputs.
Does PIX4Dcloud preserve the names/IDs?
- Yes, the project name and the names of the Tie points in PIX4Dmatic are preserved in the PIX4Dcloud project.
In which coordinate reference system will the PIX4Dcloud project be?
- The Coordinate reference system of the project in PIX4Dcloud will be the same as the project's Coordinate reference system in PIX4Dmatic, which can be found in the Status bar at the bottom of the software.
