Orthomosaic editor - PIX4Dmatic
This article provides step-by-step instructions on how to edit an orthomosaic using the orthomosaic editor in PIX4Dmatic.
Create patches
  • On the toolbar, click orthomosaic-1 Orthomosaic editor
    Captura de pantalla 2025-10-06 110026
  • Draw the patch where the orthomosaic has to be edited. Then, click on the right-click button to finish the patch creation. It is possible to draw as many patches as needed to edit the orthomosaic.
  • In the image viewer, patches will be displayed on all images that can be used to correct the orthomosaic.
ortho_editor1
Edit patch
After patch creation, the projection type has to be selected:
  • Planar: The planar projection does not preserve distances, but has fewer distortions than the Ortho projection on sharp transitions such as building edges. Therefore, it is not recommended to use planar images for mosaics dedicated to measurement applications. Its basic use is to improve the visual aspect of the Orthomosaic.
  • Orthographic: The Ortho projection preserves distances and can be used for mosaics dedicated to measurement applications.
Select an image in Planar or select one or multiple images in Orthographic projection. If multiple images are selected, they will be blended. The number of images that can be selected depends on the projection type, so it should be done before the projection selection.
Planar:
ortho_planar_mousse
Orthographic:
ortho_orthographic_mousse
Note: the processing will start automatically each time an image is selected. The patch fill will have a fading effect during processing.
fading
Before applying the patches, it is possible to modify the vertex position from 2D view moving each vertex to the new position. It is not possible modify it using the image viewer.
edit_patch_1.85
Note: If one image is selected and the patch is modified, the patch will be processed to show the new patch.
To preview the result after selecting images, you can hide the patch border from the content panel, allowing you to review the outcome before applying the patch.
showhide_patch_1.85
Apply patches
Once all required patches have been created, the final step is to click on the Apply patches button on the toolbar. All the changes will be applied to the orthomosaic.
Captura de pantalla 2025-10-06 115851
Note:  The content panel will display all patches as outdated until Apply Patches has been applied.
For each patch, in the Properties panel,  the images used to edit the orthomosaic are listed.
Captura de pantalla 2025-10-06 120859
