English
I cannot find the license in my organization account
A license may not appear in the user organization account after a purchase. Common causes are that the license is assigned to another organization account, the transaction is taking a long time to process, or the transaction has been canceled.
Issue description
Sometimes, a license may not appear in the user organization account after a purchase. This article outlines the most common reasons for this issue and provides solutions.
Before starting with the troubleshooting, ensure the license is currently missing:
  • Go to https://account.pix4d.com/ and log in with your Pix4D account.
  • Under Your organizations, select the Dashboard of your organization holding the license(s) you want to check.
  • On the left sidebar, select Plans and Licenses.
  • Make sure your license is listed in your Plans and Licenses list of the selected organization.
    • If the license appears in your organization Plans and Licenses list, you can access it through the software using this account and selected correct Organization.
    • If the license is not listed, try to select other organizations and see if the license is assigned to another organization.
    • If the license is not listed in any of your organizations, continue reading the Solutions section below.
Note: If you are having issues during purchase or during a renewal, please follow the instructions described in this article: Cannot purchase or renew a license
Solutions
If the license is not listed on your account page (https://account.pix4d.com/) under the Plan and licenses section, there could be two primary reasons:
The license is assigned to an organization where you are not part of
When you complete a purchase, the license is assigned to the an organization belonging to the account that was logged in at the time.
    • If the purchase was made by someone else belonging to a different organization or if you were logged into a different account belonging to a different organization, the license may not be correctly assigned to you.
    • If this is the case, verify which account the invoice has been sent to.
    • After identifying the correct account and organization associated with the license, you can contact the organization owner and requesting them to invite you to their organization.
    • If this is not possible, please request Pix4D technical support to transfer the license to your account.
The transaction is taking a long time to process
For invoices with larger amounts, please allow up to 24 hours for the license to be processed and created.
  • Please wait 24 hours after the purchase.
  • If after 24 hours the license has not been delivered, please Submit a request to PIX4D Support (make sure to select your product in the Product or topic your requests about field and Payment as Topic of your request) with the email address of the Pix4D account used for the purchase.
The transaction has been canceled
If multiple purchases are made in a short period or if certain transaction patterns are detected, the payment processor may block the transaction for security reasons.
  • Please contact your card provider for information regarding the reason for the transaction cancellation, and then attempt the purchase again.
  • If you are being charged but have not received a license, please Submit a request to PIX4D Support (make sure to select your product in the Product or topic your requests about field and Payment as Topic of your request) and share the order number and, if available, the invoice code.
