How to obtain coordinates from Autotags? - PIX4Dcatch
This article provides step-by-step instructions for using the tag detection feature to extract Autotag coordinates. This workflow enables accurate measurement of multiple points within a project.
Instructions on obtaining Autotag coordinates:
Evenly distributed Autotags across the project area.
On the PIX4Dcatch home screen, tap Capture at the bottom.
Before starting to capture a project, tap
the Tools icon in the bottom right corner. -
Select Tag Detection
- Turn on Detect Autotags under the Tie Points section. Tap Done.
Start capturing. Ensure Autotags are clearly detected in at least three images.
Once the capture is done, save the dataset.
- Open the captured project in the project folder at the bottom.
- Tap the three-dot icon
at the top and select Optimize
- Once the optimization is finished, tap the three-dot icon
at the top-right corner. -
Select Create Point Collection from Tie Points.
Name the point collection. Select the output coordinate reference system.
Tap Create in the top right. PIX4Dcatch will display a list of points with their coordinates. To check their geographical distribution, tap the map icon
in the top-right corner.
To export coordinate data, tap the export icon on the top. Select the desired export method for the .zip file.
Note: The Tag Detection feature can also be activated post-capture through the Optimize Autotags workflow. The subsequent processing steps remain unchanged.
