How to generate the Google Maps Tiles and KML - PIX4Dmatic
PIX4Dmatic provides the option to generate Google Map Tiles using the standard files KML for seamless integration with Google Earth and third-party GIS platforms.
Note: this feature is available from the 1.72.0 version of PIX4Dmatic or newer.
Before generating Google Maps Tiles, ensure that the following requirements are met:
  • The following processing steps have to be successfully completed: Calibration>Dense point cloud> Digital Surface Model (DSM)> Orthomosaic.
  • The Google Maps Tiles and KML files will be generated for georeferenced projects  (with image geolocation or GCPs).
To generate Google Maps tiles and KML:
  1. Create the DSM.
  2. Create the Orthomosaic.
  3. Navigate to
    1. Processing options > Exports > Orthomosaic .jpg or .tiff and click on the More more_horizontal (1) button or
      kml
    2. File > Export > Orthomosaic...
      kml_2
  4. Select .kml as Format.
  5. Select the desired File type, Compression, and Image Scale.
  6. Set the Destination path for the exported files.
  7. Click Export or Start.
Note: Please be aware that file size limitations are imposed by Google. For further details on these restrictions, we recommend reviewing the related article.
