How to export prescriptions for HORSCH sprayers - PIX4Dfields
This article explains how to create HORSCH prescription files that precisely define the treatment area, outline obstacles, and establish rates for zones.
Introduction
Creating a Targeted Operation
Exporting for HORSCH sprayers
Import to the HORSCH terminal
Introduction
HORSCH supports the import of prescription files created with PIX4Dfields, for variable rate or spot-spraying applications.
HORSCH sprayers support two types of mission:
- eosT10Pro Spot-Spraying:
- A zipped shp file containing a point geometry.
- eosT10Pro VRA-ISOXML:
- A zipped XML file containing a Variable Rate Application (VRA) map.
Targeted operations enable users to mark obstacles, no-spray and variable rate zones directly on a operations layer. These zones can be delineated based on drone, satellite and external imagery.
To create a Targeted spraying map, please follow the procedure described here: How to create a targeted spraying map - PIX4Dfields.
To export the Targeted Operation to HORSCH sprayers:
Go to the Export menu.
Click Operations.
Select the Operation to be exported.
Select HORSCH.
Select the format:
- Click Export.
A folder named HORSCH will be created and the zipped file will be saved inside it.
A folder named as the PIX4DFields project will be created and the zipped ISOXML file will be saved inside it. The file will be named as the layer in PIX4DFields.
Spot-Spraying
- Navigate to Field data > Fields.
- Click Import
- Select SpotSpray map.
- Select the Spot-Spraying file.
- Select the object to import.
- Import the SpotSpray map.
- (optional) Use Extend spots to adjust the radius of individual spots.
VRA-ISOXML
Click Import.
- Select Application maps.
- Select a file.
- Select a column.
- Select a unit.
- You can adapt the following values in the overview:
- Default value
- Not-in-field value
- GNSS-lost value
- Import the application maps
Info: More information on file import on HORSCH sprayers can be found here on their download center (external link).
