How to download the last stable version available of a PIX4D software in case of an expired Maintenance Plan
One-Time Charge (OTC) licenses with expired Maintenance Plan do not allow users to use the latest version of PIX4D software. However, users can still use the latest stable version of the software, which is available to them according to their license.
This article explains how to find and download the latest stable version of the software that can be used by a user according to the expiration date of the Maintenance Plan.
Note: This procedure is valid only for desktop software. It is not possible to download previous versions of mobile device apps.
Situation
In the case of One-Time Charge licenses (OTC) paired with a valid Maintenance Plan, the user can access the latest stable and preview versions of the software.
In the case of an expired Maintenance Plan, users can access the latest stable version of the software that was available at the moment of the Maintenance Plan expiration. In this case, the license is tied to that specific version (and older).
PIX4Dmapper
In the specific case of PIX4Dmapper, if a user is trying to log in on a newer version that their license is allowing, the "OK" button during the log in and license selection appears gray, even if license seats are still available.
Resolution
To download the latest stable version of the software available for your license, please follow this procedure:
- (if needed) If a newer, unsupported version is currently installed, uninstall it.
- Open the download page
- (if needed and requested) Log in using your associated account credentials.
- Select the organization holding your PIX4D product license and click continue.
Under Your products, locate the desired product. A personalized download button will be available for the latest version accessible with the license.
Note: If you own multiple OTC licenses for the same product with different Maintenance Plan expiration dates, only the download link for the latest version is provided. In this case, we suggest subscribing to a Maintenance Plan for your licenses. This will allow you to sync the software versions available to you.
Alternatively, if you need an older version, please ask Pixie to contact the support team to request a direct download link for a specific version.
