Generating Highest Resolution Orthomosaic Possible Given File Size Constraints
In many cases I like to generate a full resolution (1X GSD) Orthomosaic.  On larger projects (1,000 + photos) this can generate a GeoTIFF 2 or more GB in size which is too large of a file for pretty much most user's workstations to display.  In the past when using Photoscan (now Metashape) I use the option to generate a JPEG instead as the file size is much smaller than the GeoTIFF (didn't need the file to be geotagged in many cases.)
I can't seem to find a way to output a JPEG in Pix4D mapper and since a GeoTIFF of several GB is too large to load into an image editor, I'm at a loss of how to get a JPEG without exporting at less than full resolution.
Any suggested solutions?
5 comments
