Error e0400e
I have a problem with converting an old Pix4D file to use with the current release of Pix4D. The original file is from version 2.0.89 and I am using version 4.1.19.
I read in the troubleshooting that I have to open the file gradually with other versions of the software, but this means I have to mess up my Pix4D installation seriously.
I get the error e0400e and the following text:
[Error]: XML file validation failed with XSD: C:/Program Files/Pix4Dmapper/resources/xsd/0/pix4d.xsd
[Error]: Failure converting p4d file [D:/Pix4D/vaia-nov.p4d] to [D:/Pix4D/va.p4d]
[Error]: Error e0400e: Cannot open project D:/Pix4D/va.p4d. Cannot convert the project file to the latest format.
After that, when I open the converted file, Pix4D says it needs to be converted, but shows it is the same version. I tried opening with Notepad++ and the converted file looks the same as the original one. Also, there is no Optimizer - Ceres on line 35.
After this, I open the "converted"file again, Pix4D prompts for further conversion, I do it and then the result is the same Error e0400e, but the resulting Pix4D file is significantly smaller - 8KB for example.
This project I am converting is very important to me, could you give me some instructions to converting it?
Here are the links to my Pix4D files:
Original
Converted
Converted twice
Thanks in advance,
Greetings!
7 comments
