How to install the app on Remote Controllers with Screens? (APK) - PIX4Dcapture Pro
PIX4Dcapture Pro supports several drone models and their remote controllers with built-in screen. The Google Play app can't be installed on those remote controllers to download and install the app.
In this case, the PIX4Dcapture Pro Android APKs (installation file) can be downloaded and installed from the following table.
Important: APK files can be installed only on the remote controller listed on this page and will only work in combination with the compatible drone listed on this page.
Links
Note: The app is not discontinued yet. This will happen at the end of July
For now, we want to stop new users, but current users should still get support. Therefore the page about how to install an APK should still remain online.
Newer versions of PIX4Dcapture Pro will be published periodically in this table:
Warning: Since April 11, 2025, the DJI Mini 3 drone is not supported by PIX4Dcapture Pro anymore. If you are using this drone, please use another flight-planning app. You can find a list of apps in this article.
* For the DJI Matrice 300 RTK drone model, PIX4Dcapture Pro can also be installed on an external iOS or Android mobile device (phone or tablet) mounted over the Smart Controller Enterprise (screen mounting bracket and appropriate USB cable required).
** The DJI Mini 3 Pro only supports Grid Mission (Generic) inside the PIX4Dcapture Pro app. These drones don't support the Terrain Awareness feature either.
Procedures
Please note that some procedures might only be suitable for some remote controllers.
Install from a web source
1. Connect the remote controller to the internet.
2. In the main menu, tap Applications > Lightning Browser.
3. Download the APK from the table above.
4. In the main menu, tap Applications > File Manager > Downloads or Installation Package.
5. Tap on the APK file and install it.
6. In the main menu, tap Applications > PIX4Dcapture Pro.
Install using a microSD card
1. Download the APK from the table above and save it on a microSD card.
2. Plug the microSD card into the dedicated slot of the remote controller.
3. In the main menu, tap Applications > File Manager > SD Card.
4. Tap on the APK file and install it.
5. In the main menu, tap Applications > PIX4Dcapture Pro.
Install using a USB-A port
1. Download the APK from the link above and save it locally on a computer.
2. Connect the remote controller to the computer using an appropriate cable.
3. Transfer the APK on the remote controller.
When launching PIX4Dcapture Pro after the installation, ensure to give all the permissions the application is requesting.
