Technical release notes (Android/Google Play) - PIX4Dcapture Pro
Note: The application will be retired at the end of July 2025, more communications will come in the upcoming weeks.
Current Versions 1.4.0
Version | Release date | Release type |
1.4.0 |
July 16th, 2024 | Minor release |
What's new
- Minor fixes and improvements.
- Update to Android API 34.
Note: PIX4Dcapture pro APK (Build B) 1.4.0 is not available. The version 1.3.1 will be downloaded instead from the download page here when selecting the Build B.
Versions 1.3
1.3.1
April 25th, 2024 | Minor release |
1.3.0
April 1st, 2024 | Minor release |
What's new 1.3.1:
- Fix support contact email.
- Updated support links.
What's new 1.3.0:
- Update DJI SDK 4.17.
- Fixed OTC license issue.
Versions 1.2
1.2.4 | Feb 29th, 2024 | Minor release |
1.2.3 | Feb 8th, 2024 | Minor release |
1.2.2 | Dec 22nd, 2023 | Bug fixes, Improvements |
1.2.1 | Nov 13th, 2023 | Bug fixes, Improvements |
1.2.0 | Sep 26th, 2023 | Major release |
What's new 1.2.4:
- Anafi USA included in Freemium drones.
What's new 1.2.3:
- Ability to rename plans.
- Bug fixes and improvements.
What's new 1.2.2:
What's new 1.2.1:
What's new 1.2.0:
- Corridor Mission.
- New PIX4D licensing system.
- Parrot GSDK 7.7.0.
Versions 1.1
1.1.0 | July 26th, 2023 | Bug fixes, Improvements |
What's new 1.1.0:
- Search widget in the map.
- Anafi USA MIL support.
- Fixed crash when computing mission.
- Mission summary.
- Live feed widget improvements.
- Telemetry for TA.
- GSD calculation fixed.
- TA chart improvements.
- Sorting feature for mission and projects.
- Auto highlight and scroll for selected mission.
- Display grid area and circular missions radius.
- Fixed RTK connection popup not being displayed.
- Increased offline maps download region.
- User interface improvements.
- App stability improvements.
Versions 1.0
1.0.3 | July 3rd, 2023 | Bug fixes, Improvements |
1.0.2 | June 22nd, 2023 | Bug fixes, Improvements |
1.0.1 | June 5th, 2023 | Bug fixes, Improvements |
1.0.0 | May 3rd, 2023 | Initial Release |
Bug fixes and Improvements 1.0.3:
- Update Android Parrot Ground SDK 7.6.0.
- Update Android DJI SDK 4.16.4.
Bug fixes and Improvements 1.0.2:
- Fixed Parrot Anafi 4K/Thermal/USA overshooting the first waypoint in Grid Mission.
- Fixed Parrot Anafi USA camera model sometimes not recognized in the mission checklist.
- Download plans from Mission Planner with any Pix4D account.
Bug fixes and Improvements 1.0.1:
- Display a warning if no activity is detected on the drone storage during the mission.
- Display an error if the drone storage is not initialized successfully.
- Fixed duplicated camera model for Parrot Anafi drone models.
- Fixed a crash when sending all the logs from the device.
- Fixed missing manual images button in asset types.
- Fixed some missing re-computation of mission.
PIX4Dcapture Pro 1.0.0
Meet PIX4Dcapture Pro: the drone flight planning app for aerial data acquisition for 2D and 3D mapping and modeling. With its autonomous missions, this easy-to-use solution is a scalable product with professional outputs, including RTK compatibility. Suitable for every industry and powered by the photogrammetry market leaders Pix4D, this is the solution to set you apart as data collection is made easy.
Features highlights:
- Create missions from the mobile app or plan missions using the desktop and cloud-based platform PIX4Dcloud with its Mission Planner tool.
- Offline maps - plan missions in advance and download basemaps to have a visual reference when flying offline in the field.
- Terrain awareness - the drone follows the terrain to enable optimal processing for the best possible results.
- Achieve centimeter accuracy with RTK drone support.
Note: Offline maps must be downloaded to enable the Terrain awareness feature.
Workflow:
- Create a mission or plan on a cloud based platform with PIX4Dcloud’s Mission Planner tool.**
- Fly your drone!.
- Upload and analyze your data on the PIX4Dcloud platform or any desktop software by Pix4D.
Note: To access Mission Planner, a PIX4Dcloud license is required. A free 15-day trial is available.
