SETTING | DESCRIPTION |
Account details |
This section contains account details information:
Device |
This section allows the user to select the Drone and the Camera to be used to fly the missions:
Safety and Security
Minimum drone battery level: Set the minimum drone battery level under which PIX4Dcapture Pro will not allow a mission to be started or resumed. Signal lost action: Defines which action is taken in case of connection loss between the remote controller and the drone (Not connected status). The action will only be executed if the drone is not performing a mission. The options are the following:
RTH height: during the return to home, the drone will climb to this custom predefined RTH height or maintain its current altitude, whichever is higher. Restore: tap on the |
Interface |
Map orientation: defines the orientation of the Map view. Options are:
Units: defines which units are shown in the application to express distances and velocities. Options are:
Language: select the preferred language for the application. Options are:
Camera sound notifications: if this option is enabled, the device will emit a sound everytime the camera of the drone captures an image.
Network RTK |
Custom network RTK settings management:
Offline maps |
This section shows how much all the Offline maps occupy (MB) and provides the option to delete all the downloaded Offline maps from the device, including the Digital Elevation Model (DEM) used for enabling the terrain awareness feature. |
Help |
This section links to the PIX4Dcapture Pro documentation and onboarding guides (Cell tower asset, Transmission tower asset, and Grid mission). It also allows users to contact technical support and send all logs by email directly from the device. |
About |
It contains the application disclaimer, the PIX4D terms and policies, and the third-party licenses. |
