Mission types - PIX4Dcapture Pro
Mission types
Several generic missions and asset types can be selected from the PIX4Dcapture Pro new plan creation window, described in the following sections.
The Grid mission is meant to plan and fly polygonal mission shapes with a single grid flight pattern for 2D maps or a double grid flight pattern for 3D models. It is suitable for most environments that require flexible boundaries or complex mapping shapes and ensures that images are taken with the gimbal pitch and the overlap required for optimal processing.
How to position and design the mission
Once entering the Grid mission Vector.png, the default mission shape is displayed over the basemap at the current location.
Important: To facilitate the design of the mission, the settings panel (on the right side of the screen) is collapsible by tapping on the arrow tab.png.
The following actions can be performed.
  1. Move the survey area: the survey area can be displaced by tapping on the center cross view_all.png and dragging the shape to a new location.
  2. Move a vertex: tap on a vertex unnamed__1_.png and drag it to a new position to extend or reduce the survey area.
  3. Remove a vertex: two adjacent vertex can be merged by dragging one on top of the other one.
  4. Add a vertex: a vertex can be added by tapping on the “+” icon displayed over a segment.
  5. Rotate the flight lines: tap and rotate within the survey area to modify the direction of the flight lines.
Note: The Reset mission button reset.png allows the mission shape and location to be reset to the default one upon confirmation.
The How to design a grid mission onboarding guide is automatically displayed the first time a grid mission is entered and is always accessible in the general settings of PIX4Dcapture Pro (Help > Onboarding guides > Grid mission guide).
Define the mission properties
The following mission information and settings are available on the right panel.
  • Mission information:
    • Time: estimated duration of the mission execution.
    • Area [m2, ft2]: area covered by the mission.
    • GSD [cm/pixel, inch/pixel]: distance between two consecutive pixel centers measured on the ground. The GSD depends on different parameters such as the camera specifications, the flight height, and the camera angle.
  • Mission settings:
      • Flight pattern:
        • Use Single grid pattern to take images perpendicular to the ground (nadir), with the overlap required for optimal processing. Recommended in the following cases: main interest in 2D map outputs, relatively flat surface (e.g. earthworks, fields), large area.
        • Use Double grid pattern to take images from multiple sides (oblique), with the overlap required for optimal processing. Compared to the single grid, this pattern is recommended for flying closer to objects in order to capture more vertical details.
    Note: Double Grid is recommended in the following cases: main interest in 3D model outputs, surface with height fluctuations or objects (e.g. buildings, forest), small and medium area (the flight time is doubled compared to single grid pattern).
    • Terrain Awareness: This feature is turned off by default. By turning On the terrain awareness feature, the drone will follow terrain elevation changes for a consistent GSD and overlap between images. It is helpful when trying to ensure good quality data in uneven terrains.
    • Flight height [m, ft]: height of the mission in reference to the take-off location (if terrain awareness disabled) or to the terrain (if terrain awareness enabled). The range is 10 - 250m.
    • Front overlap [%]: percentage of an image covered by the next one at the ground level with respect to the flight direction. The range is 20 - 90%.
    • Side overlap [%]: percentage of an image covered by an adjacent one (in adjacent flight line) at the ground level. The range is 20 - 90%.
    • Camera angle [°]: angle of the camera during the mission execution. The range is 0° - -90° (nadir).
    • Drone speed [m/s, mph]: speed of the drone during the mission execution. The maximum speed depends on the selected front overlap and flight height. The slider allows selecting percentages (10% steps) of the maximum speed.
Note: The reset.pngRestore button can be used to reset the settings to their default values.
To generate the best 2D and 3D outputs, we highly recommend using the default mission settings values according to the selected flight pattern:
Parameters Single grid Double grid
Front overlap 80% 80%
Side overlap 70% 70%
Gimbal pitch -90° -70°
Camera parameters such as white balance (WB) and exposure compensation values (EV) can be set when the drone video feed is enlarged and when the drone is not flying a mission:
  • White balance:
    • auto_white_balance.jpg Automatic: automatically optimizes the white balance.
    • weather_sunny.jpg Sunny: optimizes the white balance for sunny weather conditions.
    • weather_cloudy.jpg Cloudy: optimizes the white balance for cloudy weather conditions.
  • Exposure value: exposure value compensation whose values range from -3 to 3.
The designed mission, along with its parameters, can be saved in the Plan folder by clicking on the save button Vector__1_.png.
Tap Start mission for the mission checklist to be displayed. If all the checks are passing, tap Fly mission. The drone exits the manual mode and performs the mission. An estimate of the time remaining until completion is displayed throughout the whole mission.
A corridor mission is a linear mission where the primary area of interest or focus is a narrow strip of land. This types of mission is useful for mapping roads, utility lines, railways, pieplines, or other linear assets.
The corridor mission is part of the generic mission. Once you enter the Corridor mission polyline-16 (1).png, the default mission shape is displayed over the basemap at the current location.
  • Mission Summary:
      • Flight time: estimated duration of the mission execution.
  • Mission settings:
      • End-mission action: This feature defines the final mission action after the mission is completed. The Return to Home option will return the drone to the home, whereas the Hover option will hover the drone after the end of the mission. The pilot has to manually bring back the drone and land it.
      • Terrain Awareness: This feature is turned off by default. By turning On the terrain awareness feature, the drone will follow terrain elevation changes for a consistent GSD and overlap between images. It is helpful when trying to ensure good-quality data in uneven terrains.
      • Flight height [m, ft]: height of the mission in reference to the take-off location (if terrain awareness disabled) or to the terrain (if terrain awareness enabled). The range is 10 - 150m.
      • Number of lines: defines the number of flight lines. The range is from 1 to 3.
      • White balance:
        • auto_white_balance.jpgAutomatic: automatically optimizes the white balance.
        • weather_sunny.jpgSunny: optimizes the white balance for sunny weather conditions.
        • weather_cloudy.jpgCloudy: optimizes the white balance for cloudy weather conditions.
Tap Start mission for the mission checklist to be displayed. If all the checks are passing, Tap Fly mission. The drone exits the manual mode and performs the mission. An estimate of the time remaining until completion is displayed throughout the whole mission.
Plan and fly an Orbit Mission around a target point. It ensures that the images are taken from all angles, with the overlap required for optimal processing. Recommended in the following cases: main interest in 3D model outputs (point cloud, mesh, etc.); isolated object (e.g. house); small area.
Once entering the Orbit mission Vector.png, the default mission shape is displayed over the basemap at the current location.
  • Mission settings:
      • Flight height [m, ft]: height of the mission in reference to the take-off location. The range is 10 - 250m.
      • Images: defines the number of images per orbit (20 - 180).
      • POI height: defines the height of the point of interest (0m - Flight height). Tap Set to current button to set the value to the current drone position.
      • Camera angle: defines the angle of the camera and is managed automatically.
      • White balance:
Plan and fly a Cylinder Mission around a tall object. It ensures that the images are taken at different levels and from all angles, with the overlap required for optimal processing. Recommended in the following cases: main interest in 3D model outputs (point cloud, mesh, etc.); isolated object (e.g. tall building); small area.
Once entering the Cylinder mission cylinder_mission_type.png, the default mission shape is displayed over the basemap at the current location.
  • Mission settings:
      • POI height: point of interest (POI) base (min) and top (max) height. The range is 0 - 250m. Tap Set to current button to set the value to the current drone position.
      • Mission height: cylinder base (min) and top (max) height. The range is 10 - 250m. Tap Set to current button to set the value to the current drone position.
      • Verticals: number of vertical lines in the cylinder mission (4 - 20).
      • Front overlap: frontal overlap between successive images in the vertical lines (60% - 90%).
Note: The restore button can be used to reset the settings to their default values.
Note: When performing a Cylinder mission, the camera angle is automatically interpolated in the vertical lines so that the camera is looking at the top of the point of interest from the top of the cylinder mission to the base of the point of interest from the base of the cylinder mission.
    • White balance:
Detailed recommendations on how to scan cell towers can be found in How to scan cell towers - PIX4Dcapture Pro.
Set the cell tower lowest point (optional)
This step can be skipped if the lowest point of the cell tower is at the same elevation as the drone take-off position.
An animated description will guide the user to determine the cell tower lowest point reference:
  • Align the drone with the lowest point of the tower.
  • Ensure the camera angle is 0°, or tap on Set to 0º
  • Point the camera at the base of the tower.
  • Tap on Next to confirm the current tower lowest point reference.
Set the cell tower center
An animated description will guide the user to determine the cell tower center reference:
  • Place the drone on top of the tower (several meters above for safety)
  • Ensure height is higher than 10 m.
  • Ensure the camera angle is -90°, or tap on Set to -90º.
  • Point the camera at the center of the tower.
  • Tap on Next to confirm the current tower center reference.
Set the cell tower highest point
An animated description will guide the user to determine the cell tower highest point reference:
  • Align the drone with the highest point of the tower
  • Ensure the camera angle is, or tap on Set to 0º
  • Point the camera at the top of the tower.
  • Tap Next to confirm the current tower highest point reference.
Mission list
The mission list is divided into 3D Model and Visual inspection categories containing all the missions to efficiently reconstruct and inspect cell tower assets.
It also shows the cell tower reference values recorded at the previous stages and provides the ability to reset them. The references will be used in some of the missions to automatically set specific settings such as the mission maximum height and the camera angle in Helix, Cylinder, and Single vertical missions.
Select one of the missions and tap Next to enter the mission settings. Upon mission completion, the mission list is automatically displayed (except for the Single vertical mission) so that a new mission can be performed.
3D Model missions
For any of the 3D model missions, camera parameters such as white balance (WB) and exposure compensation values (EV) can be set when the drone video feed is enlarged and when the mission has not been started:
  • White balance:
    • auto_white_balance.jpgAutomatic: optimizes the white balance automatically.
  • Exposure compensation: adjusts the exposure with a range from -3 to 3.
Helix
The following mission information and settings are available on the right panel:
  • Mission settings:
    • Light conditions: templates loading predefined recommended white balance and exposure compensation values according to the weather conditions (General recommendations for exposure value and white balance).
    • Mission min height: minimum height at which the drone will fly the mission (helix base). Tap Set to current to set the value to the current height of the drone (10m - 20m).
    • Mission radius: defines the radius length of the helix. Tap Set to current to set the value to the current position of the drone (6m - 12m).
    • Overlap: overlap level between images (Low, Optimal, or High).
Note: Changes to the above values will be reflected in the mission time estimate.
Orbit
  • Mission settings:
    • Capture mode: (Different capture modes are supported for DJI drones)
      • Time interval capture: time-optimized continuous flow.
      • Stop at capture point: stability and image centering optimized flow.
    • Flight direction: clockwise or counterclockwise.
    • Truncate by: truncate the mission by a specific angle (0º - 315º).
    • Images: defines the number of images per orbit. The number of images will adjust depending on the truncation degree (7 - 90).
Rather than selecting them from the mission settings, values such as Radius, Height, and Camera angle are based on the video feed on the screen, so from the current drone position, which is manually adjusted with the drone's remote controller. This is to ensure that we are viewing what we are going to scan, so having a correct point of view for the orbit images.
    • Radius: 2D distance from the previously set reference center.
    • Height: defines the height value of the orbit.
    • Camera angle: defines the camera angle which must have a negative value.
Parameters Red values interval Orange values interval Green values interval
Radius 0-5m 6-7m From 8m above
Height < 0 m 0 - 9 m From 10 m above
Camera angle -90 - (-61°) / -29 - 90° - -60 - (-30°)
Important: Red values prevent the start of the mission. Orange values do not block the start of the mission but are not recommended values. Green ones fall in the interval of the suggested values.
Cylinder
  • Mission settings:
    • Mission min height: defines the minimum height the drone should fly the mission. The value should be at least 10 m lower than the mission max height, calculated as the cell tower highest point + the radius. Tap Set to current to set the value to the current height of the drone (5m - 25m).
    • Mission radius: defines the radius length of the cylinder. The minimum and recommended value is 8 m. Tap Set to current to set the value to the current distance of the drone with respect to the cell tower center (6m - 50m).
    • Verticals: number of vertical lines in the cylinder (4 - 16).
    • Front overlap: define the front image overlap in the vertical lines (60% - 90%).
Note: When performing a Cylinder mission, the Camera angle is automatically interpolated in the vertical lines in order to look at the cell tower highest point from the mission max height and at the cell tower lowest point from the mission min height.
Single vertical
  • Mission settings:
    • Mission radius: defines the radius length of the single vertical. The minimum and recommended value is 8 m. Tap Set to current to set the value to the current distance of the drone with respect to the cell tower center (6m - 50m).
    • Front overlap: defines the image front overlap in the vertical lines (60% - 90%).
    • Flight direction: up to down or down to up.
Note: When performing a cylinder mission, the Camera angle is automatically interpolated in the vertical lines in order to look at the cell tower highest point from the mission max height and at the cell tower lowest point from the mission min height.
Visual inspection missions
For any of the Visual inspection missions, camera parameters such as white balance (WB) and exposure compensation values (EV) can be set when the drone video feed is enlarged and when the mission has not been started:
  • White balance:
Underneath orbit
  • Mission settings:
    • Truncated by: truncate the submission by a specific angle (0º - 315º).
    • Images: defines the number of images per orbit. The number of images will adjust depending on the truncation degree (2 - 32).
  • Camera angle: defines the camera angle which must have a positive value.
Radius 0-5 m 6-7 m From 8 m above
Camera angle < 0° - 0 - 90°
Orbit line of sight
  • Mission settings:
    • Images: defines the number of images per orbit. The number of images will adjust depending on the truncation degree (2 - 60).
Rather than selecting them from the mission settings, values such as Radius, Height,and Camera angle are based on the video feed on the screen, so from the current drone position, which is manually adjusted with the drone's remote controller. This is to ensure that we are viewing what we are going to scan, so having a correct point of view for the orbit images.
Camera angle All other angles -
Manual images
The drone operator pilots the drone manually with the remote controller and triggers images from custom points of views thanks to a dedicated button in the mission interface.
Detailed recommendations on how to scan transmission towers can be found in How to scan Transmission towers - PIX4Dcapture Pro.
Set the transmission tower center
An animated description will guide the user to determine the transmission tower center reference:
Set the transmission tower highest point
An animated description will guide the user to determine the transmission tower highest point reference:
  • Ensure the camera angle is, or tap on Set to 0º.
Mission list
The mission list is divided into 3D Model and Visual inspection categories containing all the missions to efficiently reconstruct and inspect transmission tower assets.
It also shows the transmission tower reference values recorded at the previous stages and provides the ability to reset them. The references will be used in some of the missions to automatically set specific settings.
3D Model missions
  • White balance:
Orbit
  • Mission settings:
Single vertical
  • Mission settings:
    • Mission min height: defines the minimum height the drone should fly the mission. The value should be at least 10 m lower than the mission max height, calculated as the transmission tower highest point + the radius. Tap Set to current to set the value to the current height of the drone (5m - 25m).
    • Mission radius: defines the radius length of the single vertical. The minimum and recommended value is 8 m. Tap Set to current to set the value to the current distance of the drone with respect to the transmission tower center (6m - 50m).
Note: When performing a single vertical mission, the Camera angle is automatically interpolated in the vertical lines in order to look at the transmission tower highest point from the mission max height and at the transmisison tower lowest point from the mission min height.
  • White balance:
Underneath orbit
  • Mission settings:
Manual images
1 out of 1 found this helpful
