PIX4Dmatic uses a standard color formatting of symbols that allows for a quick understanding of the state of what it represents. Understanding the colors of the symbols can help to assess the quality of the calibration and marks quickly.
Tiepoints (GCPs, Checkpoints, Manual Tie Points)
Intersection Tie Points
Cameras
Rays
Image Marks (GCPs, Checkpoints, Manual Tie Points)
- Blue - Indicates the initial GCP position as read from the GCP file.
- Green - Indicates the computed position of a GCP or MTP after the calibration or reoptimization step has been completed.
- Gray - Checkpoint position as extracted from the GCP file.
3D Initial GCP position. |
3D Computed GCP/MTP position. |
3D Checkpoint. |
2D Initial GCP position. |
2D Computed GCP/MTP position. |
2D Checkpoint. |
3D ITP (automatic and manual). |
aITP in Image viewer. |
mITP in Image viewer. |
Cameras
- Blue - Indicates the initial position of a camera as extracted from the image exif, or image geolocation file.
- Green - Indicates a computed position of a camera after the calibration or reoptimization step has been completed.
- Orange - Uncalibrated camera position (failed to calibrate).
3D Initial camera position. |
3D Calibrated camera position. |
3D Uncalibrated camera. |
2D Initial camera position. |
2D Calibrated camera position. |
2D Uncalibrated camera. |
Rays
- Blue - Initial position of GCP or Checkpoint before the calibration step.
- Green - Calibrated position of a 3D object after calibration or reoptimization steps.
- Yellow - Indicates which images had GCPs/MTPS/Checkpoints that were manually marked.
- Also indicates which images had ATPs automatically marked by the software.
- Magenta - Indicates images containing marks deemed as outliers.
Blue ray-Initial GCP and Checkpoint position. |
Green ray-Calibrated position of 3D object. |
Yellow ray-Manual or Automatic image mark. |
Magenta ray-Image mark deemed as an outlier. |
- Blue - GCP initial position on the image according to the GCP file.
- Yellow - GCP user-defined mark on the image.
- Green - GCP projected mark on the image after calibration or reoptimization.
GCP initial position on image. |
GCP user-defined mark. |
GCP projected mark. |
