Mounting a device to the viDoc RTK rover
It is important to mount the device to the viDoc RTK rover correctly to ensure accurate results. There are two ways to mount the device depending on the viDoc RTK rover being used.
Mount a device to the viDoc RTK rover
There are two versions of the viDoc RTK rover. One is for smartphones and requires an SP connect case to mount, while the other is for tablets and has a mechanical clamp for mounting to the tablet.
Note: SP-connect cases can be obtained when purchasing the viDoc RTK rover. They can also be purchased directly from SP-connect and most electronic, bicycle, and motorcycle shops. Refer to the manufacturer's mounting instructions for further details when mounting for the first time.
If an Android device does not have a custom case available, the SP-Connect universal mount can be used.
Smartphone model
First, insert the phone into its compatible SP-connect case. Then mount the case to the rover by following the instructions provided with the SP connect case.
Be careful to properly align the mount with the case before twisting.
Tablet model
Loosen the screw on the bottom of the viDoc, and carefully insert the tablet into the clamp. The iPad has magnets that allow you to center the viDoc. Tighten the screw to hold the tablet secure.
Be careful to avoid side buttons when mounting the tablet.
Now, with the device securely attached: Connect PIX4Dcatch to the viDoc RTK rover.
0 out of 0 found this helpful
