The viDoc RTK rover is a GNSS RTK receiver. It allows PIX4Dcatch to geolocate the images acquired by your mobile device with centimeter accuracy. It is important to connect the device to the viDoc RTK rover correctly to ensure accurate results.
Connect PIX4Dcatch to the viDoc RTK rover
PIX4Dcatch connects to the viDoc RTK rover via Bluetooth. Be sure the Bluetooth function is toggled on in the device settings.
- Turn on the viDoc RTK rover with a single long press. The green light on the rover indicates it is turned on.
- Start PIX4Dcatch.
- Select the signal indicator in the top-left corner of the screen and select viDoc RTK via Bluetooth.
Select viDoc RTK via Bluetooth.
- In the RTK Device Settings dialog:
RTK Device Settings dialog for iPhone(iOs) and Android.
- When using an Android device, measure and enter the Camera Offset Values.
For more information: How to measure the offset - PIX4Dcatch(Android) with viDoc RTK rover.
- Select the viDoc RTK rover under Select an RTK Bluetooth Device.
- Enter the NTRIP details and tap Validate:
- Hostname / IP
- Port number
- Username
- Password
For more information: What is NTRIP?
- When the connection is established, select Choose mountpoint and select the preferred mountpoint.
- Select the NTRIP coordinate system.
- Tap Connect.
A successful connection to the NTRIP service is indicated with a green RTK icon.
With the device properly connected to the viDoc RTK rover, it is ready to capture a project and measure points.
For more information: Capture a project with PIX4Dcatch and viDoc RTK rover.
