How to interpret the Signal quality indicator dialog - PIX4Dcatch
The Signal Quality Indicator displays information about signal strength, connectivity, and the expected accuracy of location data. Understanding these indicators helps ensure data is captured under optimal accuracy conditions.
Integrated GPS sensor
When launching PIX4Dcatch, the application uses the mobile device’s built-in GPS. The signal quality is displayed in the Connection Card, located in the top-left corner of the capture screen.
The connection card displays the quality of device reception, including the expected horizontal and vertical accuracy.
RTK device via Bluetooth
When a PIX4D-supported RTK device connects successfully via Bluetooth, the RTK dialog displays detailed connection information. The screen displays information about the connection status and the resulting accuracies.
Header
  • The header gives a quick overview of the RTK connection:
    • RTK icon: Indicates a successful connection to the RTK device.
    • Satellite Count (26): A numerical value showing the number of satellites used in the connection (updates in real time).
    • NTRIP RTK Status: Indicates the type of RTK NTRIP connection.
      • RTK Fixed: Accuracy in the range of a few centimeters (inches). This is the optimal status for the capture
      • RTK Float: Accuracy in the range of 1m (3ft)
      • DGNSS Only: Accuracy in the range of up to 10m (33ft)
      • Autonomous GNSS fix: Accuracy in the range of more than 10m (33ft)
      • No Fix: The data is invalid due to insufficient satellite coverage or internet connectivity issues.
The status label depends on the RTK device. For example, Trimble Catalyst DA2 may show HD-RTK or RTX instead of RTK Fixed. Always check the horizontal and vertical accuracy values as well as the label.
  • RTK vertical and horizontal accuracy estimations.
    • Shows the expected accuracy based on the current signal.
  • HDOP and VDOP (Horizontal/Vertical Dilution of Precision).
    • Indicates the current quality of the position and distribution of the satellites.
Generally, an HDOP value below 1 is considered ideal. To achieve centimeter-level accuracy, it has been observed that the highest accuracy is achieved with a value below 0.65.
The VDOP value is considered ideal when it is below 1.5. To achieve centimeter-level accuracy, it has been observed that the highest accuracy is achieved with a value below 1.
Status
For optimal results, wait until the RTK status is Fixed before starting data capture. Monitor the status throughout acquisition, as it may fluctuate. If RTK Fixed is lost, move slowly to an area with better reception and avoid overhead obstructions. Once RTK Fixed is restored, PIX4Dcatch can compensate for short periods of reduced reception.
Accuracy
Indicates the expected positional accuracy for the current connection and RTK status. Once an RTK Fixed solution is established, both horizontal and vertical accuracy values should be within a few centimeters.
In ideal conditions:
  • Horizontal Accuracy (H): Improves (the value decreases) as the RTK signal becomes more stable. This value should be within a few centimeters and, under ideal conditions, approach 0.01 m (0.03 ft).
  • Vertical Accuracy (V): Improves (the value decreases) with RTK signal stability. This value should also be within a few centimeters and, under ideal conditions, approach 0.01 m (0.03 ft).
Accuracy values can vary and are influenced by several factors, including:
  • Blocked and reflected GNSS signal, close to buildings, trees, and/or bridges.
  • Rapid movements of the device.
  • Poor cellular reception.
For best performance, keep the antenna upright during data acquisition.
If PIX4Dcatch disconnects from the RTK receiver.
If the RTK device disconnects, PIX4Dcatch automatically attempts to reconnect to the RTK device. If this happens during a capture, the capture is paused. If reconnection fails, tap the RTK disconnected notification.
Select whether to continue capturing without RTK or to reconnect manually.
Note:  If Capture without RTK-Fixed is blocked in Settings Restrictions, the capture button stays unavailable until the status is RTK Fixed. If Permit override when no RTK-Fixed is on, the app counts down 60 seconds while trying to get an RTK fix, then lets you retry or continue without RTK Fixed.
