Stitching artifacts - PIX4Dfields
This article discusses the causes of artifacts in orthomosaics, when processing multispectral or RGB images.
Graphic card drivers issue
This is a common problem. The artifacts look really strange. Many colors are present, and it's a combination of big and small squares, images are scrambled, looking like a Picasso painting.
While processing, the images stitch, and they look fine, but when the map is finally done, it is full of artifacts.
Example artifacts:
image-20240207-091921   image-20240228-113329
This is commonly related to outdated graphic card drivers.To solve this:
  • Update graphic card drivers.
  • After updating drivers and restarting the device, process the imagery again.
  • If the problem persists, import the imagery again and disable GPU acceleration under Advanced settings - Processing options.
Color balance
Different colors between images can generate "Honey comb" effect:
Honeycamb_effet
To solve this issue and improving the color transitions in the orthomosaic:
Insuficcient overlap
When overlap is insuficcient, processing may fail or artifacts can occur in the orthomosaic.
1-1
Ensure overlap is more than 70% for both side and frontal overlap.
Corrupted images
Non-nadir or distorted images can generate artifacts.
663c4be9-ac3f-48c1-a391-777454db1b03 (1)-1
To solve this issue, inspect the images around the area and discard them when processing.
