Stitching artifacts - PIX4Dfields
This article discusses the causes of artifacts in orthomosaics, when processing multispectral or RGB images.
Graphic card drivers issue
This is a common problem. The artifacts look really strange. Many colors are present, and it's a combination of big and small squares, images are scrambled, looking like a Picasso painting.
While processing, the images stitch, and they look fine, but when the map is finally done, it is full of artifacts.
Example artifacts:
This is commonly related to outdated graphic card drivers.To solve this:
After updating drivers and restarting the device, process the imagery again.
If the problem persists, import the imagery again and disable GPU acceleration under Advanced settings - Processing options.
Color balance
Different colors between images can generate "Honey comb" effect:
To solve this issue and improving the color transitions in the orthomosaic:
- Import the images again.
- Enable Full Blending under Processing options.
Insuficcient overlap
When overlap is insuficcient, processing may fail or artifacts can occur in the orthomosaic.
Ensure overlap is more than 70% for both side and frontal overlap.
Corrupted images
Non-nadir or distorted images can generate artifacts.
-1.png?width=290&height=290&name=663c4be9-ac3f-48c1-a391-777454db1b03%20(1)-1.png)
To solve this issue, inspect the images around the area and discard them when processing.
