Preference settings - PIX4Dmatic
The Preferences dialog gives access to the General and Network settings allowing the user to customize the PIX4Dmatic workspace.
Access: On the Menu bar, click Edit > Preferences.
General
In the General tab it is possible to change the following settings:
  • User interface:
    • Language: select the preferred language for the application. Options are:
      • Chinese.
      • English.
      • French.
      • Japanese.
      • Spanish.
        Note: The default language set will be determined by the keyboard settings.
  • Project handling:
    • Default folder path: Select default folder.
  • Viewer
    • 3D: Default background color: Select default background color.
    • 2D: Basemap enabled (requires a network): Toggle to enable and disable a basemap.
      The General tab of preference settings.
Network - Proxy configuration
Local networks protected by proxies can cause issues with detecting licenses. A warning No license available is displayed. If a proxy server is used to connect to the Internet, enter the proxy settings, following:
0 out of 0 found this helpful
