Preference settings - PIX4Dmatic
The Preferences dialog gives access to the General and Network settings allowing to customize the PIX4Dmatic workspace regarding the language used, the folder path, the views, the software updates, and the proxy configuration.
Access:
Windows: On the Menu bar, click Edit > Preferences.
Mac: On the Menu bar, click PIX4Dmatic > Preferences.
General
In the General tab it is possible to change the following settings:
User interface
  • Language: select the preferred language for the application. Options are:
    • Chinese.
    •  English.
    •  French.
    •  Japanese.
    •  Korean.
    • Spanish.
      Note: The default language set is determined by OS language.
Project handling
  • Default folder path: Select the default folder.
Viewer
  • 3D: Default background color: Select default background color.
  • 2D: Basemap enabled (requires a network): Toggle to enable and disable a basemap.PIX4Dmatic preferences general
    The General tab of preference settings.
Software updates
  • Notify when preview releases are available: Option is disabled by default. To get notified when preview releases are available toggle on to enable the option.
Network - Proxy configuration
Local networks protected by proxies can cause issues with detecting licenses. A warning No license available is displayed. If a proxy server is used to connect to the Internet, enter the proxy settings, following:
  1.  Open the Proxy window by clicking Network...
  2. There are three options to choose from:
    • No proxy
    • Use System proxy
    • Manual proxy configuration
    PIX4Dmatic preferences network
  3. Ask your system administrator which option to choose from the Protocol drop-down list (http,https,Socks4 Socks5, ). If you do not know choose Use system proxy.
  4. Enter the proxy Host name and Port number.
  5. Enter the proxy Username and Password.
  6. Click Done.
Offline license
The Offline license tab offers the tools to request and activate an offline license.
If you received an offline license file (.lic) from Pix4D, drag and drop it to this window (or click PIX4Dmatic import button Import file from disk and select the .lic file).
To request an offline license, contact your reseller or contact us providing us with the Hardware ID. To copy the Hardware ID in your clipboard, click the copy button PIX4Dmatic copy button next to the Hardware ID.
PIX4Dmatic preferences offline
The Offline license tab of preference settings.
Important: It is necessary to open the software and copy the Hardware ID while using the device that will be used for offline use. The license will be valid only on that specific device.
Information: Additional information on how to request and activate an offline license can be found in this article: Trial, sign up, log in and offline license - PIX4Dmatic.
0 out of 0 found this helpful
