Technical release notes (iPadOS) - PIX4Dscan
Download the latest version for iPadOS.
Current Versions 1.9.0
1.9.0 January 17th, 2022 Updates, Improvements
Version 1.9.0
What's new
  • Support for Parrot Anafi Ai
  • Helix mission to replace cylinder and orbits for cell towers with no nearby obstacles
  • Support for Portuguese (Brazil) language
  • Update to DJI SDK 4.15.2
  • Update to Parrot GSDK 7.0.0
Improvements
  • Fix occasional crashes with some iPad devices
  • Improved user interface
Versions 1.8.0
1.8.0 November 3th, 2021 Updates, Improvements
Version 1.8.0
What's new
  • Orbit line of sight mission to visualize the Cell Tower surroundings
  • Update to DJI SDK 4.15.1
Improvements
  • Send all logs from device: logs sometimes not being sent due to file size limit
  • Other bug fixes
  • UX improvements
Versions 1.7.0
1.7.0 September 16th, 2021 Updates, Improvements
Version 1.7.0
What's new
  • Ability to create an asset or generic projects containing multiple missions
  • Access the project list from the flight view or the map view
  • Browse and delete projects from the project list
  • Enter the project information to review partially or fully flown missions
Improvements
  • Bug fixes
Versions 1.6.0
1.6.0 July 21st, 2021 Updates, Improvements
Version 1.6.0
What's new
  • Support for DJI Matrice 200 Series V2
  • Support for DJI Mavic 2 Zoom
  • Support for DJI Zenmuse X5S camera with default DJI lens
Improvements
  • DJI drone connectivity
  • DJI mission reliability
  • Bug fixes
Versions 1.5.0
1.5.0 May 27th, 2021 Updates, Improvements
Version 1.5.0
What's new
  • Choose between time interval and waypoint image capture mode in cell tower orbit mission
  • Select flight direction (clockwise, counterclockwise) in cell tower orbit and cylinder missions
  • Ability to truncate mission plans in cell tower orbit and cylinder missions
  • Support for DJI Matrice 200 Series with DJI Zenmuse X4S camera in generic mission types
  • Update to DJI SDK 4.14
  • Update to Parrot GSDK 1.8.0. This version is only compatible with Anafi firmware 1.8.0, please upgrade your drone to the last firmware available
Improvements
  • Cell tower flight plan optimizations
  • UI improvements
  • Bug fixes
Versions 1.4.0
1.4.0 March 23rd, 2021 Updates, Improvements
Version 1.4.0
What's new
  • Optional reference step to set minimum cell tower height in case it's not equal to the drone take-off height
  • Drone and camera name and connectivity displayed in-flight view
  • French language support
Improvements
  • Cell tower orbit missions: valid gimbal pitch ranges have been updated and minimum height limitation has been removed
  • UI improvements
  • Bug fixes
Versions 1.3.0
1.3.0 Feb 1st, 2021 Updates, Improvements
Version 1.3.0
What's new
  • Grid mission for 2D maps and 3D models
  • Onboarding guide for designing grid missions
  • Minimized drone live feed
  • Drone to POI distance indicator in telemetry
  • Camera azimuth indicator in telemetry for cell tower inspection
Improvements
  • Minimum drone battery level selection to start a mission in safety and security settings
  • Minimum controller battery level to start a mission has been lowered to 20%
  • UI improvements
  • Bug fixes
Versions 1.2.0
1.2.0 Nov 26th, 2020 Updates, Improvements
Version 1.2.0
What's new
  • Onboarding guide for designing cell tower data acquisition plans
  • Frontal overlap for cylinder and single vertical line missions
  • Center on mission button in map view
Improvements
  • UI improvements
  • Bug fixes
Versions 1.1.0
1.1.0 Oct 7th, 2020 Updates, Improvements
Version 1.1.0
What's new
  • Single vertical mission for Cell Tower solution (when cylinder can’t be performed due to obstacles)
  • Light condition template selection at mission planning (for better point density in antenna 3D reconstruction)
  • Offline login and usage
  • Update to DJI SDK 4.13.1
  • Update to Parrot GSDK 1.7.0
  • Support for Parrot Anafi Thermal (RGB only)
Improvements
  • Cell Tower submission completeness feedback
  • Send log files to any email address in the help section
  • Consult Pix4D terms and policies in about section
  • Reduce the minimum point of interest height to 10m
  • Ability to leave flight view for dashboard drone selector
  • Ability to cancel an ongoing RTH
  • Improved handling of errors at the login
  • Start and End mission labels
  • Display drone flight trace during the mission
  • Other bug fixes and improvements
Versions 1.0.0
1.0.0 July 20th, 2020 Initial release
Version 1.0.0
PIX4Dscan is a professional asset flight application for iPad developed by photogrammetry experts for visual inspections from images. This companion of PIX4Dinspect allows for both manual and automatic drone flights (Cell Tower, Orbit or Cylinder), to meet your mission’s specific needs and to collect actionable data.
Workflow
1- Select a mission - Select a mission on your iOS device. PIX4Dscan comes with built-in flight plans for vertical structures. It also includes an adaptable, semi-automatic flight plan specifically designed for cell towers. The app guides you to set the right parameters for an actionable dataset.
2- Start and fly - Track your mission's progress with the map view or monitor live with camera view. PIX4Dscan provides live telemetry data such as altitude, speed, gimbal pitch and more.
3- Upload and inspect - Upload images or videos (only available for Parrot Anafi) from your SD card to PIX4Dinspect to create accurate and easy to inspect 2D and 3D models.
0 out of 0 found this helpful
