With a captured PIX4Dcatch project, there are several options for processing a 3D model from it. Directly upload and process to PIX4Dcloud / PIX4Dcloud Advanced for the most immediate results, or export the project and process using PIX4Dmatic or PIX4Dmapper.
Upload and process to PIX4Dcloud / PIX4Dcloud Advanced
For fast results, uploading and processing with PIX4Dcloud / PIX4Dcloud Advanced can provide quick shareable 3D reconstructions.
Upload directly from the project
Captured project ready for upload.
After capturing a project, upload directly to PIX4Dcloud / PIX4Dcloud Advanced for processing by tapping the blue Upload button at the top of the screen.
Upload from the Projects screen
It is also possible to upload from the Projects screen. The Projects screen lists all of the projects taken on the mobile device.
1. Tap the folder icon to access the Projects screen.
2. Tap and hold on the desired project to access the menu.
3. Tap Upload.
Upload Project processing options
After tapping Upload the Upload project window appears providing further options for processing the project.
Select processing options with the Upload Project dialog.
- Measure Volumes and Elevation Profiles: Select the option to generate a DSM.
- 2D Map: Select the option to generate an Orthomosaic.
- Use classic image processing: The classic PIX4Dmapper based pipeline. This process will not include depth data from LiDAR capable devices.
4. An email is sent when all images are uploaded and processing begins.
5. A second email is sent when processing is finished.
6. After the processing is finished, the results can be viewed and shared on PIX4Dcloud.
Process locally with PIX4Dmapper or PIX4Dmatic
1. Export the project from the device to the computer. For more information see How to export PIX4Dcatch projects (iOS/Android).
2. Create a new project and start processing using PIX4Dmapper/PIX4Dmatic. For more information see:
3. After the processing is finished, the results are available for further analysis in PIX4Dmapper/PIX4Dmatic.
