Supported drones, cameras and controllers - PIX4Dscan
PIX4Dscan is compatible with iPad (iPadOS)  and tablet (Android) devices only. The PIX4Dscan app requires iPad OS 11.0/ Android 7 or later. We recommend using the latest iPadOS version as it is usually the one used for internal testing. PIX4Dscan has been tested with the following devices:
  • iPad Mini 5th gen, iPad Pro 2nd gen, iPad 7th gen, iPad Air 2.
  • Samsung Galaxy Tab A7, Samsung Galaxy Tab S7
PIX4Dscan is compatible with the following drones, cameras, and controllers.
Manufacturer Drone Camera Controller iOS Android
DJI drones Phantom 4 Built-in Default GL300C Compatible - Not tested (1.0.0 and later) Compatible - Not tested (1.0.0 and later)
Phantom 4 Pro Built-in Default GL300F Compatible (1.0.0 and later) Compatible (1.0.0 and later)
Phantom 4 Pro V2.0 Built-in Default GL300L Compatible (1.0.0 and later) Compatible (1.0.0 and later)
Phantom 4 RTK* Built-in Default GL300L (SDK remote controller) Compatible - Not tested (1.5.0 and later) Compatible - Not tested (1.0.0 and later)
Mavic 2 Pro Built-in Default RC1A Compatible (1.0.0 and later) Compatible (1.0.0 and later)
Mavic 2 Zoom Built-in Default RC1A Compatible (1.6.0 and later) Compatible (1.0.0 and later)
Matrice 200** DJI Zenmuse X4S/X5S*** Default GL6D10A Compatible (1.5.0 and later) Compatible (1.0.0 and later)
Matrice 200 V2  DJI Zenmuse X4S/X5S*** Default GL900A (Cendence) Compatible (1.6.0 and later) Compatible (1.0.0 and later)
Matrice 210** DJI Zenmuse X4S/X5S*** Default GL800A (Cendence) Compatible (1.5.0 and later) Compatible (1.0.0 and later)
Matrice 210 V2 DJI Zenmuse X4S/X5S*** Default GL900A (Cendence)  Compatible (1.6.0 and later) Compatible (1.0.0 and later)
Matrice 210 RTK** DJI Zenmuse X4S/X5S*** Default GL800A (Cendence) Compatible (1.5.0 and later) Compatible (1.0.0 and later)
Matrice 210 RTK V2  DJI Zenmuse X4S/X5S*** Default GL900A (Cendence)  Compatible (1.6.0 and later) Compatible (1.0.0 and later)
Parrot drones Anafi Ai Built-in Default SkyController 4 Compatible (1.9.0 and later) Not Compatible
Anafi Built-in Default SkyController 3 Compatible (1.0.0 and later) Compatible (1.1.0 and later)
Anafi Thermal Built-in (RGB only) Default SkyController 3 Compatible (1.1.0 and later) Compatible (1.1.0 and later)
Anafi USA Built-in (RGB only) Default SkyController 3 Compatible (1.1.0 and later) Compatible (1.1.0 and later)
Phantom 4 RTK*  – No RTK corrections available. We recommend disabling the RTK corrections from the vendor application otherwise this drone might not be able to start a mission in PIX4Dscan.
M200 Series** – Cell tower mission not available.
X5S*** –  For the DJI Zenmuse X5S, the compatible lense model is DJI MFT 15mm/1.7 ASPH.
Tip: The following drones are not officially tested by PIX4Dscan. However, you will be able to fly your mission if you select the appropriate settings in PIX4Dscan:
  • Anafi USA & Anafi Thermal: Select Anafi drone in PIX4Dscan's  Drone selector dropdown list.
Disclaimer: Pix4D publishes this information as a courtesy to its customers. Because this information may not be accurate, Pix4D makes no warranty of any kind, expressed or implied, with respect to its validity.
0 out of 0 found this helpful
