Technical release notes (Android) - PIX4Dscan
Download the latest version for android.
Versions 1.2.0
1.2.0 January 17th, 2022 Update
New Features, Improvements
What's New
  • Helix mission to replace cylinder and orbits for cell towers with no nearby obstacles
  • Support for Portuguese (Brazil) language
Improvements
  • Drone video feed was not displayed on some Android devices
  • Improved user interface
Versions 1.1.0
1.1.0 November 18th, 2021 Update
What's New
  • Support for Parrot Anafi and Anafi Thermal (RGB only)
  • Orbit line of sight mission to visualize the Cell Tower surroundings
  • Ability to create an asset or generic projects containing multiple missions
  • Access the project list from the flight view or the map view
  • Browse and delete projects from the project list
  • Access the project information to review partially or fully flown missions
  • Update to DJI SDK 4.15.1
Improvements
  • Bug fixes
  • Improved user experience
Versions 1.0.0
1.0.0 September 22nd, 2021 Initial release
Version 1.0.0
PIX4Dscan is a professional asset flight application for tablets developed by photogrammetry experts for visual inspections from images. This companion of PIX4Dinspect allows for both manual and automatic drone flights (Cell Tower, Orbit, Cylinder, Grid), to meet your mission’s specific needs and to collect actionable data.
Workflow
1- Select a mission - Select a mission on your Android device. PIX4Dscan comes with built-in flight plans for vertical and horizontal structures. It also includes an adaptable, semi-automatic flight plan specifically designed for cell towers. The app guides you to set the right parameters for an actionable dataset.
2- Start and fly - Track your mission's progress with the map view or monitor live with the camera view. PIX4Dscan provides live telemetry data such as altitude, speed, gimbal pitch, and more.
3- Upload and inspect - Upload images for your SD card to PIX4Dinspect to create accurate and easy to inspect 2D and 3D models.
Drone compatibility list:
- Phantom 4 Pro V2
- Phantom 4 Pro
- Mavic 2 Pro
- Mavic 2 Zoom
- Matrice 200, 210, 210 RTK
- Matrice 200 V2, 210 V2, 210 RTK V2
0 out of 0 found this helpful
