Mesh - PIX4Dmatic
Mesh
Note: since version 2.4.0, processing can be paused and resumed at any time as long as the project remains open. There is no need to cancel and start over. If processing is paused and the project is about to be closed, the following message will appear.
InputPipeline
Texture size
Sky mask
Template
Deghosting
Model simplification
Polygon-aware
Interior improvement
Mask-aware
Exports
The following processing options can be adjusted when enabling the mesh generation
- Click Process
. - On the Menu bar, click Process > Mesh...
- In the menu bar, click View > Switch to 3D, or
- Click the 3D button on the screen
, or
Input
It allows selecting the input point cloud for the Mesh generation. The following options are available:
- Dense point cloud (default): The point cloud generated from images during the Densify step.
- Depth point cloud: The point cloud generated from LiDAR depth maps.
- Depth & dense fusion: The point cloud that presents a fusion of the dense and depth point cloud.
Important: In case the input is not selected, the start button is not enabled, and a warning message will appear in the processing panel.
Note: Mesh texturing is supported only with RGB images; thermal images are not supported.
Pipeline
Defines the trade-off between processing time and mesh detail.
- Scalable: Produces the highest-quality mesh with maximum detail. Because it automatically scales to provide the right amount of detail for any project size, this is the default recommendation when accuracy and visual fidelity are top priorities.
- Fixed-size: Designed primarily for compatibility with third-party software that requires specific constraints, such as exporting a single OBJ file with a single texture.
- Default: Automatically determines an "optimal" triangle count and texture size tailored to the geometry of a small mesh. Suitable for quick previews or standard software compatibility.
- Custom: It allows you to define an exact number of triangles in the mesh. Additionally, it is possible to select the texture size.
Note: For small meshes, the scalable and fixed-size mesh pipelines offer comparable processing times and mesh quality, unless the texture size or triangle count is severely constrained.
Texture size
Specifies the resolution of the mesh texture. The value ranges from 1024 × 1024 to 32768 x 32768 pixels, with a default of 16384 × 16384 pixels. Higher values result in more detailed textures but increase memory usage and processing time.
Sky mask
Sky mask utilizes the generated mask during the Dense point cloud step to improve the mesh quality. It is enabled by default when the Sky filter option is enabled while running the Dense point cloud step.
Template
This option enables distinguished default parameters for the mesh generation algorithms used for the different types of datasets imported into the software. The following templates are available for the Mesh generation:
- Nadir. Optimized for nadir aerial data.
- Oblique. Optimized for oblique aerial data.
- PIX4Dcatch: For projects with limited extent. Optimized for hand-held captured data with PIX4DCatch.
Controls the level of mesh decimation to reduce file size and complexity while balancing detail when the scalable pipeline is selected.
- Weak: Preserve finer details. Recommended for captures of close objects.
- Moderate: Simplify finer details. Recommended for generic PIX4Dcatch scenes or merged projects containing PIX4Dcatch data.
- Strong: Stronger simplification. Recommended for nadir scenes.
Deghosting
This setting adjusts the parameters used during mesh generation to handle outliers and improve results in complex scenes. It can help remove unwanted objects or artifacts, particularly in datasets with high geometric complexity or motion.
The following deghosting modes are available:
- Weak (default): Suitable for general use. Applies mild outlier filtering, which helps in most cases. However, it may introduce artifacts around thin structures (e.g., cables, antennae) or moving objects.
- Strong: Applies more aggressive outlier filtering. Recommended for highly complex geometry (e.g., telecom towers) or scenes with significant motion (e.g., crowded streets). This setting may reduce color saturation and sharpness in some areas.
Polygon-aware
This option, when selected, enables the use of polygons to improve the mesh quality. It is possible to select or deselect the desired layers, that have been created in the project. This option is only enabled when at least one polygon is created and associated with a layer.
Important: The mesh should be generated or reprocessed after editing a polygon.
PIX4Dmatic allows for the manual creation of polygons. To create these features, ensure that a point cloud is visible, click on Tools, and select Polygon. Alternatively, the keyboard shortcut P can activate the tool. Once activated, vertices will snap to the point cloud, MTPs, or ITPs. Left-click to add vertices. Right-click to add the final vertex and complete the polygon.
After creating the polygon, the following options are available by right-clicking:
- Invert selection
- Delete polygon
- Move to layer
- Flip face orientation
- The face orientation indicates the direction in which the faces of the polygon are oriented. This option can be enabled via Settings > Viewing option. Correctly setting the direction of the faces provides for a better mesh reconstruction and viewing experience. It is essential that the faces of the polygon are oriented toward the direction of the cameras used during image capture. To adjust face orientation, right-click on the plane and select Flip face orientation.
- Set polygon to planar
- Set polygon to non-planar
- Create section from polygon
When creating and editing Planes for interior scenes, it is recommended to use the Backface culling feature in the Settings. When enabled, this feature allows for backward transparency for the Planes. The Plane will be opaque when viewed from the front. However, it will be transparent when viewed from behind. This allows for an obstructed view of interior scenes.
Mark-aware
Masks can be applied during mesh generation to exclude elements from the resulting mesh
Exports
From the Exports section, the following can be exported after processing the Mesh step:
- Point cloud from mesh .laz
- Mesh
Pointcloud from mesh .laz
PIX4Dmatic allows the generation and export of a point cloud derived from the mesh. During export, users can select the Default point density (pts/m³) or define a Custom value. The expected file size and total number of points are displayed before export. This process enables the creation of a complete point cloud, including areas that were not directly reconstructed, effectively filling any gaps. The resulting point cloud is exported in compressed .laz format.
Mesh
The following formats are available when exporting the Mesh:
- OBJ: mesh and texture exported in a single file.
- Export CRS as Default: PIX4Dmatic exports the mesh as an .obj file in a local coordinate system centered on the project. The mesh is not georeferenced. The project_name_offset.xyz file contains the project offset and is saved in the same folder as the .obj file. In external viewers that support offsets, applying this file correctly positions the mesh while preserving the precision of the mesh displayed in PIX4Dmatic.
- Export CRS as Project CRS: PIX4Dmatic exports the mesh georeferenced in the project's coordinate reference system (CRS). The values in the .xyz offset file are 0 because no positional correction is required.
- PLY: When this format is chosen, the texture coordinates can be picked between per face and per vertex. Meshes with per vertex coordinates can be imported in Blender and Meshlab. Meshes exported with per face coordinates can be imported into Meshlab.
- Cesium 3D Tiles: The Cesium 3D Tiles are georeferenced. This format allows the Mesh to be easily shared and displayed across many third-party software and 3D platforms. The primary purpose of 3D Tiles is to improve the streaming and rendering performance of massive heterogeneous datasets. The foundation of 3D Tiles is a spatial data structure that enables Hierarchical Level of Detail (HLOD). When selecting and exporting the Cesium 3D Tiles a .json file and various .b3dm files are generated inside the folder project_name-cesium_mesh.
- slpk: A Scene Layer Package (SLPK) file is an openly published file format for 3D geospatial data, designed as a package for storage or exchange that captures all resources for a "scene layer" structured according to the Indexed 3D Scene Layer (I3S) specification. Mesh (LOD) can be exported as .slpk for ESRI compatibility. The SLPK Mesh file is geo-referenced, and the exported multi-LOD mesh in .slpk format is named project_name-mesh.slpk.
- fbx. This is a 3D file format used to store and exchange complex 3D data. It supports geometry, and textures. making it suitable for transferring entire 3D scenes with third-party software.
- Texture size. The value ranges from 1024 × 1024 to 16384 x 16384 pixels
- Level of detail. Number of triangles to be exported (from 0 to 9)
Note: Exporting the mesh to SLPK requires the horizontal CRS to have an EPSG code, and the vertical CRS to be ellipsoidal heights or to have an EPSG code as well
Note: Texture will not be displayed with MeshLab.
INFO
- Please be aware that the option to export to the SLPK format is not available in versions 1.75.0 and 1.76.0.
- The mesh is exported tiled from version 1.77.0 to 1.79.0
