Volume measurement - PIX4Dsurvey
Volume measurement
PIX4Dsurvey's volume measurement is using the triangulated method between the volume's base polygon and the surface defined by a local TIN in the resolution of the project GSD. This method connects all the vertices and triangulates the volume above and below the base surface.
How to create a new volume
  1. On the Tools bar, select the volume measurement tool by clicking on volume_icon.png.
    Volume measurement selection.
  2. To draw a Volume, left-click on points in the 3D view. Right-click or press Enter to complete the Volume base polygon.
  3. (Optional) To mark the vertices more accurately, select the volume by clicking ic_cursor_black.png on it. Then you can correct the position of each vertex in the 3D view, on images, or using the vertex editor.
After drawing the volume, details about the volume measurement are displayed. More specifically:
  • Name of the volume and name of the layer the volume belongs to. The name of the volume layer and color of visualization can be edited.
  • 3D perimeter, 3D area, minimum and maximum elevation will be displayed according to the drawn polygon.
    Display of volume measurement details, after drawing the volume.
Note: A new volume layer can be added by selecting the add.png icon of the Volume layers on the left sidebar. The volume can be moved to another volume layer or vector layer by right-clicking on it.
How to compute the volume
Once the volume is drawn, click Compute in Measurements to trigger the volume computation.
Compute the cut/fill volume measurements by clicking on Compute button.
After volume measurements are completed, cut/fill volume and error are displayed.
Cut/fill volume and error are computed after the completion of volume measurements.
More specifically:
  • Cut volume [units3]: Volume that is above the volume base. The volume is measured between the volume base and the surface.
  • Fill volume [units3]: Volume that is below the volume base. The volume is measured between the volume base and the surface.
  • Total volume [units3]: The total volume (cut + fill volume).
How to export a volume report
After computing the (cut/fill) volume measurements, the Volume report is available to be exported. PIX4Dsurvey_Volume_export.png
To export the Volume report:
  1. On the Menu bar, click File, then Export. Alternatively, on the top right, click export.jpg Export. The Export panel opens on the right.
  2. In the Export panel, select the output format (PDF, HTML, CSV, or LandXML)
  3. (Optional) Unselect the output Volume layers that do not need export.
  4. In the Destination section, navigate to the path where you want to save the files.
  5. Click Export.
How PIX4Dsurvey calculates the Volume measurement
PIX4Dsurvey calculates the volume as follows:
1. A new volume is drawn. For more information on how to draw a volume: How to create a new volume. volume
A volume is drawn.
Note: PIX4Dsurvey creates the base taking into account the altitude of each vertex.
The base of the volume.
2. PIX4Dsurvey projects a grid with GSD spacing on the base.
Projected grid on the base of the volume: This drawing is a sketch and does not depict the real dimensions of the grid. The grid has very small interval (the GSD).
3. For each cell i of the grid, its volume (Vi) is given by:
Vi = L* Wi * Hi
Where:
L= the length of the cell.
Wi = the width of the cell.
Hi = the height of the cell.
The Length (Li) and Width (Wi) are equal to the project's GSD.
L=W= GSD
The Height (Hi) is given by:
HiZTi - ZBi
Where:
ZTi = the terrain altitude of each cell at the center of the cell.
ZBi = the base altitude of each cell at the center of the cell.
Therefore, the volume Viof cell i is given by:
V= GSD*GSD* (ZTi - ZBi)
Note:
  • ZTi is the altitude of the 3D terrain corresponding to the center of the cell i.
  • ZBi is the altitude of the base surface of the volume corresponding to the center of the cell i .
Volume of one cell of the base
4. PIX4Dsurvey calculates 2 volumes:
    • The Cut volume Vcis the volume between the base and the 3D terrain, when the terrain is higher than the base.
Cut volume = VC VC1 + VC2 +...VCN
Where:
VC1...N = Cut volume for cell i..N
    • The Fill volume Vis the volume between the base and the terrain when the terrain is lower than the base.
Fill volume = VVF+ VF2 +...VFN
Where:
VF1...N = Fill volume for cell i...N.
Note: The Fill Volume is given with negative value/sign.
5. The Total volume is given by:
Total Volume = VT =VCVF
0 out of 0 found this helpful
