Customized PDF report - PIX4Dfields
This article explains how to set up and export a custom PDF report in PIX4Dfields.
Important: The settings for the custom PDF can be found in the dashboard Setting.jpg Settings.
The PDF report is exported from inside an opened project.
Set credentials (name, address, email)
To set a name, address, and email for a customized PDF:
  1. On the dashboard click setting icon Settings, and click on Customize PDF report.
  2. Fill in a name, address, email, and phone into the respective fields.
customized pdf setting
Note: Not all fields are required. Empty fields will not be displayed in a customized PDF.
Set a logo for a custom PDF
Click on Add logo to upload a .jpg image as a logo inside a customized PDF report.
add logo to PDF
Note: A square image no larger than 1MB in data size is recommended. Larger images lead to larger PDF file sizes.
Export customized PDF report
To export your customized PDF report:
  1. Inside an opened project, click Export.
  2. Select PDF report.
  3. Fill in a Report title, choose which layers will appear under Select layers, and add a Description if needed.
  4. If logo and company information needs to be added select Custom PDF.
  5. Click Continue.
pdf export menu
6. The color of the annotations, the basemap, and the format could be selected.
pdf export menu
7. Click Export
Example of a custom PDF
PDF report example
PDF report example
PDF report example
PDF report example
