Customized PDF - PIX4Dreact
 Previous  |  Next
Important: You find the settings for the custom PDF in the dashboard settings and the export functionality inside an opened project.
Set an own icon for your custom PDF
To set an own icon for your custom PDF:
  1. Go inside the dashboard settings and click on Customize PDF report.
  2. Click on Add logo to upload an own image you want to be displayed as your icon inside your customized PDF report.
Note: A square image not larger as 1MB in data size is recommended. Larger images lead to a larger PDF file size.
Delete own icon for your custom PDF
Delete or change an own icon for your custom PDF:
  2. Click on Delete logo to delete the existing image.
Set own credentials (name, address, email)
To set your name, address, and email for your customized PDF:
  2. Fill in your name, address, and email into the respective fields
Note: You do not have to fill in all fields, just the ones you want to be displayed. Non-filled fields will not be displayed in your customized PDF.
Export customized PDF
To export your customized PDF:
  1. Inside an opened project, click Export.
  2. Select the export type PDF report.
  3. Select Custom PDF.
  4. Choose your other export options
  5. Click Export on the bottom of the right side tab.
Important: If you entered any custom credentials they will be displayed at the bottom of every page. If you added a logo it will be displayed on the right upper area of every sheet, replacing the Pix4D logo.
0 out of 0 found this helpful
