The image captured in a Pix4Dcatch app can be exported from the device. The exported image files can then be processed using Pix4Dmapper or manually uploaded to Pix4Dcloud for processing.
Export using an external drive
Export using Google Drive or other file sharing options
- Connect the device to the external Flash drive.
- Launch the Pix4Dcatch app.
- In the Home screen, tap
and select the project.
- Tap
to export the files.
- A new window with sharing options will appear. Tap Files.
- The list of the hardware to export will appear. Select the external flash drive and tap Save.
- Use the external flash drive to copy the project to the computer.
- Tap
- The new window with sharing options such as Email, Google Drive, Dropbox, etc.. will appear. Tap on Save to Drive.
- Tap on Folder to select the destination folder. After selecting the destination folder, tap Save.
- The project is saved as a compressed file. Download the file and use the file extractor such as 7-Zip to extract it. You can also use the online Zip Extractor to extract the files in the Google drive.
- Right Click on the Project > Open with > ZIP Extracto >
- After the extraction is completed, click
to access the extracted files.
