Get started with real data
Download any of these projects for free* and explore Pix4Dmatic functionalities with a real dataset.
Using real data demonstrates what Pix4D software can do and will help you understand what’s needed when collecting your own data.
Not sure where to begin? Follow the instructions below each data set to create your first project.
Pix4Dmatic example projects
Industrial zone and agriculture area download dataset
The goal of this project is:
The dataset with 1469 images (senseFly, AeriaX) and 8 GCPs contains an industrial zone, suburban houses, and the surrounding agriculture area. The dense point cloud, images, and GCPs are displayed in the 3D view. |
General project information | |
Project | |
Location | Switzerland |
Average Ground Sampling Distance (GSD) | 2.28 cm / 0.9 in |
Area covered | 1.154 km2 / 115.4 ha / 0.446 sq. mi. / 285.3 acres |
Output coordinate system | WGS 84 / UTM zone 32N - EPSG 32632, WGS 84 ellipsoid |
Image acquisition | |
UAV | eBee X (senseFly) |
Image acquisition plan | 4 flights, single grid flight plan |
Camera | senseFly AeriaX |
Images | |
Number of images | 1469 |
Image size | 6000 x 4000 pixels |
Image geolocation coordinate system | WGS84 - EPSG 4326, WGS 840 ellipsoid |
Ground control points (GCPs) | |
Number of GCPs | 8 |
GCPs coordinate system | WGS84 - EPSG 4326, WGS 84 ellipsoid |
Download project files |
The dataset can be downloaded here (14.7 GB). The downloaded compressed .zip file contains the following files and folders:
Instructions |
Open the .p4m Pix4Dmatic project file |
This section describes how to open the .p4m project.
Once the project is successfully imported, the images and GCPs appear in the 3D view. |
Urban area download dataset
The dataset with 100 images (senseFly, AeriaX) and 3 GCPs was flown over a town. The dense point cloud, images, and GCPs are displayed in the 3D view. |
Project | |
Average Ground Sampling Distance (GSD) | 2.41 cm / 0.95 in |
Area covered | 0.0214 km2 / 2.14 ha / 0.008 sq. mi. / 5.3 acres |
Image acquisition plan | 1 flights, single grid flight plan |
Images | |
Number of images | 100 |
Image geolocation coordinate system | WGS84 - EPSG 4326, WGS 84 ellipsoid |
Number of GCPs | 3 |
The dataset can be downloaded here (0.99 GB). The downloaded compressed .zip file contains the following files and folders:
Instructions |
