Orthomosaic
Create an orthomosaic based on the digital surface model (DSM) and the images.
Access:
- Click Process
- On the Menu bar, click Process > Orthomosaic...
It allows users to change the following processing options:
Important: The orthomosaic receives as input the DSM and the position of the original image. If the DSM is noisy or the reconstruction is not optimal, the orthomosaic will be distorted. Make sure that the results of the Calibrate, Densify, and the DSM are optimal before generating the Orthomosaic.
Tip: If holes are present in the generated orthomosaic, enable the
Interpolation parameter in the DSM processing options before generating the orthomosaic:
Orthomosaic generated with DSM - Interpolation enabled.
Orthomosaic generated with DSM - Interpolation disabled.
Resolution
- Resolution: Defines the spatial resolution used to generate the orthomosaic.
- The orthomosaic resolution is the same as the resolution of the DSM. For example, if the DSM resolution is set to 5 cm then also the orthomosaic resolution is 5 cm.
Exports
Note: The Exports - Orthomosaic GeoTIFF option is disabled by default. To export the orthomosaic process:
- On the Menu tab, click File > Export orthomosaic...
- In the Export orthomosaic dialog, select the export settings.
- Click Export.
