Previous | Next |
Import an annotation as GeoJSON
Annotate a layer
Edit an annotation
Add a description to an annotation
Add attachments to an annotation
Fill the area of the annotation
Reuse an annotation
Export an annotation
Delete annotations
To import annotations as GeoJSON:
- Click Annotate at the top right of the window.
- Click the layer where you want to add an annotation.
- Click on the menu next to ANNOTATIONS at the bottom left of the window.
- Click Import.
- Navigate to the folder containing the file and select it.
- Click Open.
Annotate a layer
To add annotations to a layer:
- Click Add Point, Add Line, or Add Area.
- Left-click to add each new vertex.
- Click Accept to finish digitizing the annotation or click Cancel to discard the annotation.
- Add a Title (mandatory) and Description (optional) to the annotation.
- Click Create.
Edit an annotation
To edit an annotation:
- Select the layer and annotation to edit.
- At the bottom of the right sidebar, under ANNOTATIONS, enable Edit.
- Drag and drop a vertex to relocate it.
- For lines and polygons, click the "plus" sign between two vertices to add a new vertex.
- For lines and polygons, drag and drop a vertex on top of an adjacent vertex to delete it.
- For lines and polygons, drag and drop the annotation to relocate the entire annotation.
To add attachments to an annotation:
- Click the menu (three dots) besides Attachments.
- Click Attach images.
- Click Open.
To add a description to an annotation:
- Under DESCRIPTION, write a description.
Fill the area of an annotation:
- Under ANNOTATION, enable Area Fill.
Reuse an annotation
To reuse an annotation:
- Select the layer and annotation to reuse.
- Click the menu (three dots) next to ANNOTATIONS.
- Click Reuse.
- Click the white cross symbol in the middle of the annotation that appeared and drag it to relocate the annotation.
- Click Accept.
- Click Create.
To export an annotation:
- Click the Export at the top right of the window.
- Under EXPORT, click Annotations.
- Under Select layer, select the layer.
- Select the annotation to export.
- Click Export.
- Navigate to the folder where you want to export the annotation.
- In File name, write a name for the file.
Delete annotations
To delete annotations:
- At the bottom left of the window, under ANNOTATIONS, click the bin icon next to the name of the annotation you want to delete.
- In the pop-op window, click Yes.
