Outputs of PIX4Dmatic
The following table presents PIX4Dmatic's main output files:
DSM |
.tiff (GeoTIFF) |
Export the generated DSM. The image compression, file type (single, tiles), and image scale can be defined. |
.tfw |
World File for TIFF. Contains the location, scale, and rotation of image. |
.prj |
Coordinate Reference System file. |
Orthomosaic |
.tiff (GeoTIFF) |
Export the generated Orthomosaic. The image compression, file type (single, tiles), and image scale can be defined. |
.jpg (Georeferenced with .jgw ) |
Export the generated Orthomosaic. The quality (%) and image size (S, M, L) can be defined. |
.tfw |
.prj |
GCPs marks |
.txt, .csv |
File with GCPs marks that can be imported into other PIX4Dmatic projects. |
MTPs marks |
.txt, .csv |
File with MTPs marks that can be imported or exported into other PIX4D products. |
PIX4Dmatic project file |
.p4m |
PIX4Dmatic project file that can be used to open existing projects in PIX4Dmatic or PIX4Dsurvey. |
Point cloud |
.bpc |
Pix4D's proprietary .bpc file format is optimized for loading and manipulating large point clouds. It is generated and exported automatically during the Densify step. |
.las |
Exported generated dense point clouds in .las version 1.2. |
Mesh |
.obj, .mtl, .jpg, offset.xyz |
Mesh can be visualized in PIX4Dcloud, Windows 3D Viewer, Meshlab, Global Mapper, Rhino, 3ds Max, 3DBuilder, or Autodesk Maya. |
Quality report |
.pdf, .txt |
Quality report to assess the accuracy and quality of projects. .pdf on Windows, .txt on macOS. |
