English
Recommended hardware - PIX4Dmatic
The following article describes the minimum and recommended hardware and software requirements for PIX4Dmatic. PIX4Dmatic supports both Windows and macOS platforms.
Minimum requirements
  Windows_logo_-_2012 Windows Apple_logo_black.svg macOS
Operating System  Windows 11 (64-bit) Sequoia (15.x) + Sonoma (14.x)
CPU Quad-core or hexa-core Intel i5 Apple M1 or newer
GPU Any (NVIDIA/Intel/AMD) GPU that supports OpenGL 4.1 or higher  Apple Integrated GPU
RAM 32 GB (2,000-5,000 images at 20 MP).
64 GB (5,000-10,000 images at 20 MP).
Disk Space* SSD, 150 GB - 300 GB Free space (2,000-5,000 images at 20 MP).
SSD, 300 GB - 450 GB Free space (5,000-10,000 images at 20 MP).
Note: PIX4Dmatic supports GPU hardware acceleration to enhance performance during key processing steps, including calibration, densification, and orthomosaic generation. Currently, only NVIDIA GPUs are supported for this feature, as they utilize CUDA (Compute Unified Device Architecture)—a parallel computing platform required for acceleration. AMD GPUs and systems running on macOS are not compatible with CUDA and, therefore, cannot benefit from GPU hardware acceleration in PIX4Dmatic at this time.
Important: PIX4Dmatic has been tested with datasets containing up to 10,000 images at 20 megapixels each. For optimal performance and stability, it is recommended to split datasets larger than 10,000 images into multiple projects. This approach helps ensure smooth processing and prevents potential issues related to memory and processing limits.
Note: Windows 10 is not supported since Windows stopped supporting this operating system.
Windows 10 support has ended on October 14, 2025
Recommended (Windows only)
Operating System Windows 11 (64 bits)
CPU Intel i7, i9, Xeon
GPU
GeForce GTX 10 series, or RTX series
RAM
64 GB (2,000-5,000 images at 20 MP)
128 GB (5,000-10,000 images at 20 MP)
Disk space*:
SSD, 250 GB - 400 GB Free space (2,000-5,000 images at 20 MP)
SSD, 400 GB - 550 GB Free space (5,000-10,000 images at 20 MP)
Gaussian Splatting
RAM At least 16GB of VRAM
CUDA compute capability greater than 6.1. Lower versions are not supported
Note*: The recommended values for available disk space do not include the additional space required to store input images or exported results. These recommendations specifically apply to workflows that include the Mesh processing step and the export of a 3D Mesh, which can significantly increase storage requirements.
Important: This information is based on Pix4D's testing experience and should be used as a general guide, not as a guarantee.
macOS - Legacy support (hw & sw)
Important announcement for Apple_logo_black.svg macOS : PIX4Dmatic Hardware Compatibility Update
From version 1.64, PIX4Dmatic will support Apple devices with Apple silicon processors (M1, M2, M4, and all variants). Apple devices with Intel processors should continue using PIX4Dmatic version 1.63 and avoid future updates. Maintain the PIX4Dmatic license according to hardware specifications. This update enhances compatibility with the latest hardware innovations.
Important:
  • From PIX4Dmatic version 1.72.0, macOS Ventura (13.x) is no longer supported.
  • From PIX4Dmatic version 1.61.1, macOS Monterey (12.x) is no longer supported.
  • From PIX4Dmatic version 1.46.0, macOS Big Sur (11.x) is no longer supported.
  • From PIX4Dmatic version 2.3.0, macOS Sonora (14.x) is no longer supported.
