Previous | Next |
The outputs of Pix4Dcloud consist of photogrammetric results and of post-processing outputs, such as annotation files.
Photogrammetric outputs
Post-processing results and workflows
When creating a new dataset to process on Pix4Dcloud, the following standard outputs (with default formats) can be generated and are made available for their web visualization, according to the template that was selected for processing during step 3. Processing template.
Point Cloud
Extension | Description |
.las | Point Cloud file(s). |
3D Textured Mesh
.obj | OBJ 3D Mesh with texture files. |
DSM
.tif | DSM file. |
Orthomosaic
.tif | Orthomosaic file. |
NDVI
.tif | NDVI map file. |
Reports
In parallel, some reports are generated to verify the success of the processing results.
.pdf, .xml | Quality report of the project. |
Pdf report for AutoGCP marks. For Pix4Dcloud Advanced users only. | |
.log | Application logs, generally used for troubleshooting. |
A wider variety of formats and outputs can be generated and processing options selected if the project files are uploaded from Pix4Dmapper. More information on customized processing options in How to customize the options for processing on Pix4Dcloud. A full list of downloadable files is available in How to download results from the Cloud.
Annotation files
After the dataset is processed on Pix4Dcloud and/or available for its web visualization, annotations can be added and later on exported to third-party software or to other Pix4Dcloud datasets.
More information on how to export annotations and which formats are supported for their export in How to export/import annotations.
Download/Export results
Outputs from Pix4Dcloud can be downloaded individually or as a results folder. More information on how to export outputs in Download/Export.
Share
Outputs from Pix4Dcloud can be shared for collaboration purposes. More information in Share.
