How to export/import annotations on Pix4Dcloud
Export
Import
Important: Read about the supported coordinate systems for exporting and importing annotations in Georeferencing of datasets, outputs and annotations on Pix4Dcloud.
Export
Distances, areas and markers can be exported in three different formats:
  • CSV (properties of the annotations only): available both in the 2D and 3D views.
  • GeoJSON (georeferenced annotations): available both in the 2D and 3D views.
  • Shapefile (georeferenced annotations): available both in the 2D and 3D views.
To export an annotation layer:
1. Ensure each annotation has the desired name and, optionally, a description.
2. On the left sidebar, click the Annotations layer's name. This highlights all the annotations of the layer in the current view.
3. Click cloud_download.png.
4. Select the export format. Clicking automatically starts the download.
Note: Annotations cannot be exported individually. The entire Annotations Layer is exported at once.
Import
Distances, areas, and markers can be imported in two different formats:
  • GeoJSON (georeferenced annotations): Available both in the 2D and 3D views.
  • Shapefile (beta) (georeferenced annotations): Available both in the 2D and 3D views.
Warning: The GeoJSON file has a custom structure in order to be read by the application. Ensure the imported GeoJSON file reflects the formatting rules of the exported one. To check the format of the file, create some annotations, and export the layer.
Warning: For shapefile import, the entire folder with the 4 .dbf, .prj, .shp, .shx files should be zipped in a folder (.zip) and the folder imported.
To import the annotations:
1. On the left sidebar, click the Annotations layer's name.
3. Select the file format.
4. Browse for the desired file.
0 out of 1 found this helpful
