Settings - PIX4Dcatch
Use the Settings dialog to adjust and customize features within the PIX4Dcatch app. There are several features to consider allowing for customization and improved workflows. This article outlines each setting and describes its function. Tapping Reset will return to the default selections.
Access: Tap the settings button button to access the Settings menu.
PIX4Dcatch settings dialog window
PIX4Dcatch Settings dialog
Image Trigger Method
Toggle between Device Pose or Image Overlap to select the image trigger method for capture. Only one method is active at a time. The default triggering method is Image Overlap.
Note: It is advised to use the default settings. Test any adjustments before employing them in critical projects.
Device Pose
PIX4Dcatch settings device pose toggle
Toggle for Device Pose
Images are triggered based on the movement and rotation of the device.
  • Distance: Triggers when the device moves more than the selected distance. The default value is 10 cm, and the distance can be set between 1 cm to 100cm.
  • Angle: Triggers when the device has rotated more than selected degrees. The default value is 20°, and it varies between 1° and 45°.
Image Overlap
PIX4Dcatch settings image overlap toggle
Toggle for Image Overlap
Images are triggered based on the image overlap.
  • Overlap: Triggers when overlap goes below the selected value. The default overlap is 90%, and the overlap percentage ranges between 70% and 99%.
Advanced settings
Features available depend on the device used for capture. Please select the device make for detailed information.
Apple iPhone/iPad Advanced Settings
Capture Quality
PIX4Dcatch capture quality settings
PIX4Dcatch iOS Capture Quality settings
  • Warning Sounds: Receive audible warnings during capture.
  • Auto Focus: Sets the camera settings as autofocus.
  • Skip Low-Quality Images Will perform some checks if the device is moving too fast and will not take photos. A warning message is shown on the screen during the capture.
  • Resolution: Sets the resolution for the captured images. Resource dependency will increase with the selection of higher resolutions including increased process times and extra storage requirements.
    PIX4Dcatch iPhone resolutions selection settings
    PIX4Dcatch iOS Resolution settings
    • Normal: Lower than 4k*
    • 4K: Approx. 4K*
    • Maximum Resolution: above 4k*
* Depends on the device. Refer to the device specifications for more information.
Access: iPhone 11 or later and iPad Pro (5th generation) or later.
View
PIX4Dcatch iOS settings view
PIX4Dcatch iOS View settings
  • Shown Cameras: Display the camera indicator (image pyramid) for each captured photo.
  • Show Feature Points: Display the feature points as detected by the device. More feature points mean better accuracy.
Mesh
PIX4Dcatch iOS Mesh settings
  • Save Mesh: Save the Mesh OBJ file for export.
  • Enable Mesh: Generates a Mesh from LiDAR depth data. Available only for devices with LiDAR.
  • Mesh Settings: Set the mesh type and mesh colors.
    PIX4Dcatch iOS mesh settings
    • Mesh Type
      • Mesh | Wireframe: Display the mesh or cameras as wireframes.
    • Mesh Color: Allows to adjust the color of the mesh and/or the camera indicators based on the provided color bands. The value ranges from 0 to 1.
Other
PIX4Dcatch iOS other settings
PIX4Dcatch iOS Other settings
  • Save Video: A video of the capture session is saved.
Android Advanced Settings
View
PIX4Dcatch android view settings options
PIX4Dcatch Android View settings
Mesh Color
PIX4Dcatch android mesh color settings options
PIX4Dcatch Android Mesh Color settings
Other
PIX4Dcatch android other settings options
PIX4Dcatch Android Other settings
24 out of 25 found this helpful
2 comments
  • Stéphane ROC
    Is there a way to chose the picture's resolution?
    I took picture with an iPhone 12 Pro and the maximum image file is 1Mo. How can I increase the quality?
  • George Brown
    Hello,
    Due to the technology we are using for Pix4Dcatch, the resolution is limited by the device hardware and manufacturer provided SDKs, currently the resolution cannot be increased.
    Kind Regards
    George Brown
