Settings (Android, iOS) - PIX4Dcatch
Getting Started
Settings
Access: In the iOS version, tap mceclip0.png,  and tapDefault1.png in the android version.
SETTINGS DESCRIPTION
IMAGE TRIGGER METHOD
Device Pose: Images are triggered based on the movement and rotation of the device.
  • Distance: Triggers when the device moves more than the selected distance. The default value is 10 cm and the distance can be set between 1 cm to 100cm.
  • Angle: Triggers when the device has rotated more than selected degrees. The default value is 20° and it varies between 1° and 45°.
This option is only available on the iOS version. Toggle to use the overlap to trigger the image capture. Only one is active at a time. The default triggering is based on the device pose.
Image Overlap: Images are triggered based on the image overlap.
  • Overlap: Triggers when overlap goes below the selected value. The default overlap is 95% and the overlap percentage ranges between 75% and 99%.
Advanced Settings
VIEW
  • (Android, iOS) Shown Cameras: Display the camera indicator (image pyramid) for each captured photo.
  • (Android, iOS) Show Feature Points: Display the feature points as detected by the device. More feature points mean better accuracy.
  • (iOS) Show Overlap: Colors the mesh to show the achieved overlap. Available only for the device with LiDAR.
  • (iOS) Mesh | Wireframe: Display the mesh or cameras as wireframes.
  • (iOS) Show Movement Path: Display the points that show the movement of the device throughout the capture session.
MESH COLOR: Allows to adjust the color of the mesh and/or the camera indicators based on the below color bands. The value ranges from 0 to 1.
  • Red
  • Green
  • Blue
  • Opacity
OTHER
  • (Android, iOS) Auto Focus: Sets the camera settings as an auto focus.
  • (iOS) Skip Low Quality ImagesWill perform some checks if the device is moving too fast and will not take photos. A warning message is shown on the screen during the capture.
  • (iOS) Save Video: A video of the capture session is saved.
Reset
 Reset all settings to defaults.
18 out of 19 found this helpful
2 comments
  • Stéphane ROC
    Is there a way to chose the picture's resolution?
    I took picture with an iPhone 12 Pro and the maximum image file is 1Mo. How can I increase the quality?
  • George Brown
    Hello,
    Due to the technology we are using for Pix4Dcatch, the resolution is limited by the device hardware and manufacturer provided SDKs, currently the resolution cannot be increased.
    Kind Regards
    George Brown
