Technical release notes (iOS) - PIX4Dcatch
This article provides an overview of PIX4Dcatch iOS version releases, including version, release date, and release type, along with key new features, improvements, updates, and bug fixes.
 Download the latest version for iOS.
Version 2.25
2.25.0 July 23, 2026 Updates, improvements, and bug fixes
2.25.1 July 30, 2026 Bug fixes
2.25.2 August 12, 2026 Updates, improvements, and bug fixes
2.25.3 August 17, 2026 Bug fixes
2.25.3
What’s new:
  • Bug fixes.
2.25.2
What’s new:
  • Enhanced depth mesh overlay in capture view.
  • Support for GCG05 and CR-2005 geoid models.
  • Organization specific settings for designated account roles.
Improvements & Bug fixes:
  • Restored offline export support for all regions.
  • Fixed GCP transformation bug causing altitude discrepancies.
  • Fixed an issue about defining GPS origin that affected reconstructions in rare cases.
2.25.1
What’s new:
  • Bug fixes.
2.25.0
What’s new:
  • Improved AR capture performance and stability.
  • Immersive staking feature, guiding to points in AR (3D) and on a map (2D).
  • You can now check your other apps while Catch projects upload in the background.
  • See your credit status and seat availability.
  • Added support for LN02 transformation for Trimble RTK.
  • Added support for importing CAL CRS files.
  • Improved RTK auto-reconnect and clearer disconnect error warnings.
  • RTK device ID bug: information is visible in the quality report again.
  • Improved UX in the capture and settings screen.
  • Fixed an OPF processing error bug.
  • Fixed missing image metadata when saving projects.
Version 2.24
2.24.0 May 7, 2026 Updates, improvements, and bug fixes
2.24.1 June 15, 2026 Bug fixes
2.24.1
Bug fixes:
  • Fix for timing error.
2.24.0
What’s new:
  • Upload projects to PIX4Dcloud in background while continuing to use the app.
Bug fixes:
  • Fixed export/upload issues on devices without LiDAR.
Internal notes:
  • Reintroduced background upload functionality.
  • Fixed the issue of causing excessive API calls when refreshing projects from cloud.
  • Fixed duplicate events in Mixpanel tracking.
  • Added logs for cloud API calls to improve monitoring and debugging.
Version 2.23
2.23.0 April 22, 2026 Bug fixes
2.23.1 April 29, 20026 Bug fixes
2.23.1
Bug fixes:
  • Fixed seat release issue affecting some organizations.
2.23.0
Bug fixes:
  • Hot fix for critical bug causing timeout error.
    Version 2.22
    2.22.0 April 20, 2026 Updates, improvements and bug fixes
    2.22.0
    What’s new:
    • Create & export checkpoints to verify the accuracy of your 3D model in PIX4Dcloud or PIX4Dmatic.
    • Reduced project saving time.
    • Improved capture performance and fixed memory-related crashes.
    • Improved accuracy reporting with Bad Elf Mini RTK.
    • Fixed missing PLY and GLTF export options after processing.
    Versions 2.21
    2.21.0 March 3, 2026 Updates, improvements and bug fixes
    2.21.1 March 19, 2026 Bug fixes
    2.21.1
    Bug fixes:
    • Bug fix for export to third-party app.
    2.21.0
    What’s new:
    • Navigate to a point in AR from the Survey tab.
    • View and find selected points with realtime guidance in AR.
    • View your point collection in map view.
    • Improved NTRIP connection handling.
    • Improved Leica RTK connection stability.
    Versions 2.20
    Version Release date Release Type
    2.20.1 February 2, 2026 Improvements and bug fixes
    2.20.0 January 21, 2026 Updates, improvements and bug fixes
    2.20.1
    • Optimized connection stability with Bad Elf Mini RTK and its companion app.
    • Improved upload experience.
    • Text and localization updates.
    2.20.0
    What’s new:
    • Projects are visible and accessible from the Map view.
    • Support for Liquid Glass UI on iOS 26 with new app icon.
    • Improve Project Quality Metrics.
    • Enhanced RTK and Bluetooth stability (for BadElf and Leica RTKs), including better reconnect handling.
    • Improved performance of PIX4Dcloud AR.
    • Improved annotation handling, including positioning and cloud synchronization.
    • Fixed issues when exporting projects.
    • Fixed multiple crashes and stability issues related to survey tab, capture, and upload to PIX4Dcloud.
    • General improvements and UI issues.
    Versions 2.19
    2.19.1 December 15, 2025 Bug fixes
    2.19.0 December 2, 2025 Updates, improvements and bug fixes
    2.19.1
    What’s new:
    • Support latest Leica RTK workflow, for improved stability and compatibility with updated Leica devices.
    • Fix Leica RTK auto-connection issues for more reliable and effortless connection experience.
    2.19.0
    What’s new:
    • Support Emlid RX2 RTK.
    • Improve project optimization on saving.
    • Improve stability and accuracy of AR points, PIX4Dcloud AR.
    • Fix issue connecting to SAPOS NTRIP.
    • General improvements and bug fixes.
    Versions 2.18
    2.18.0 November 17, 2025 Updates, improvements and bug fixes
    2.18.0
    What’s new:
    • Project Quality:
      • Introduced Project Quality Report available when saving projects.
      • Quality report includes image sharpness, RTK accuracy distribution, and capture parameters to help users assess data completeness and accuracy.
    • Import & Coordinate Systems:
      • Added more flexible support for importing WKT files for any CRS, including Site Localization WKT.
      • Users can now select any file type when importing WKT.
    • Account Management & re-upload:
      • Better handling of local projects status across multiple organizations and accounts.
      • Allow re-upload the same local project to PIX4Dcloud.
    • Capture & Device Compatibility:
      • Added support and automatic SPC+ offsets for iPhone 17 Pro and Pro Max models.
      • Updated capture screen and project view for improved visibility and device compatibility.
    • RTK connection:
      • Improved reporting of RTK accuracy and quality.
      • Improved handling of RTK connection failures and related error messages.
      • Fixed issue where RTK accuracies were cut off or displayed inconsistently.
      • Fixed Leica RTK profiles being deleted after upgrading to the latest app version.
      • Fixed issue of not validating the NTRIP after editing an existing profile.
      • Fixed crashes with viDoc RTK autoconnect on project startup.
    • Performance & Stability:
      • Improved app stability when saving video and capturing simultaneously.
      • Fixed capture freeze issue when saving video is enabled.
      • Fixed unresponsive Done button when enabling detailed annotations.
      • Reduced app lag during project list and RTK profile operations.
      • Better accurate image EXIF data.
    • Project Management & Upload:
      • Fixed project deletion not working properly.
      • Fixed projects containing frames with duplicate timestamps.
      • Fixed logout and login issues requiring multiple attempts.
      • Fixed issue where upload to PIX4Dcloud could fail due to nil CRS.
      • DSM and Ortho upload options are now OFF by default to save bandwidth and processing time.
    • Import & Export:
      • Added OPF generation for multi-export workflows.
      • Improved export structure and ensured new file organization applies during multi-export.
      • Enable export of dense point cloud in PLY format and improve progress feedback.
    • UI & User Experience:
      • Updated app disclaimer and translate it into Korean language.
      • Added area display when computing volume.
      • Improved live preview appearance, dark/light mode support, and fixed transparent background issues.
      • Enhanced main project view buttons and overall visual consistency.
      • Fixed multiple UI issues with iOS 26.
      • General UI improvements & fixes.
    Versions 2.17
     2.17.1 October 03, 2025  Bug fixes
     2.17.0  October 02, 2025 Updates, improvements and bug fixes
    2.17.1
    Bug fixes:
    • Fix issue of not showing uploaded projects with old PIX4Dcatch versions.
    2.17.0
    What’s new:
    • Device & Hardware Support:
      • Support Bad Elf Flex Mini RTK rover.
      • Support custom iPad case in Japan mounting Emlid RTK with iPad M4 11-inch.
      • Added iPad Casetify SPC+/SPC camera offsets.
      • Drop support for iOS 17.
    • Capture & Appearance:
      • Capture screen redesigned for better high visibility in the field.
      • Ability to block captures without RTK-fixed from the Settings Restriction option.
      • Support annotations for high-resolution captures, with improved marking, clearer warnings, and fixes when uploading to PIX4Dcloud.
    • Coordinates & Geoid Support:
      • Ability to import WKT in CRS selection dialogs, for point collections and when uploading to PIX4Dcloud.
      • Support the Finnish geoid model FIN2023N2000 with EPSG:3900 “N2000 height”.
    • RTK & Capture performance:
      • Improved RTK connection and handling of NTRIP information.
      • Fix lagging when showing the list of RTK profiles.
      • Fix issue of offsets not always passed through URL-scheme for external apps.
      • Improved app performance during capture.
      • Fix capture quality issue when having the app in background before starting the capture.
      • Fix tag detection issues during capture.
      • Improved video saving so that recordings are preserved even if the app crashes.
    • Export & Upload:
      • Removed 2000-image limit for Gaussian Splatting when uploading to PIX4Dcloud.
      • Enforced scalable 3D mesh generation when uploading to PIX4Dcloud.
      • Optimized point cloud exports and improved progress feedback.
      • Ability to export the dense point cloud as PLY.
      • Continue export if OPF files generation failed.
      • Fix “camera_list.json” OPF file for devices without LIDAR.
      • The new file structure migration is now applied during multi-export and multi-upload operations.
    • Warnings & Messaging:
      • Show the “What’s new” popup highlighting updates when opening the app after upgrading.
      • Show warning when detecting ARKit bad positioning.
      • Show warning dialogs when not having enough storage when starting a capture and when recovering projects.
      • Better warning handling when creating point collections.
    • UI & Usability:
      • Fix issue of not able to click on the login and create account tabs.
      • Fix issue of not able to capture reference photos for point measurements.
      • Reduce delay when importing points.
      • Resolved multiple crashes and UI glitches.
      • General UI improvements.
    Versions 2.16
    2.16.0 August 21, 2025 Updates, improvements and bug fixes
    2.16.1 August 27, 2025 Bug fixes
    2.16.1
    Bug fixes:
    • Fix issue of having a failure when using PIX4Dcloud AR.
    2.16.0
    What’s new:
    • Add annotations during capture
      • Mark annotations in AR, name them and add descriptions.
      • An image is captured automatically when marking and attached to the annotation.
      • Display annotation names directly in AR view.
      • Upload annotations to PIX4Dcloud.
      • Create point collections from annotations.
    • Select SLPK format when uploading to PIX4Dcloud.
    • Added a progress bar when saving projects.
    • Improve warnings and show critical heating notifications during capture.
    • General performance optimization.
    • Improved failure handling when connecting to Leica RTK rover.
    • Fixed crash occurring during capture.
    • Fixed missing RTK serial number in images EXIF metadata.
    • Fix issue of not able to create an RTK profile.
    • Fix issue incorrect recommended CRS display when select output CRS.
    • Fix exporting captured pointcloud (.PLY).
    • General UI improvements and fixes.
    Technical notes:
    • The annotations during capture are uploaded as MTPs to PIX4Dcloud.
    Versions 2.15
    2.15.0 July 31, 2025 Updates, improvements and bug fixes
    2.15.1 August 06, 2025 Bug fixes
    2.15.1
    Bug fixes:
    • Fix Japanese language texts.
    2.15.0
    What’s new:
    • Generate OPF file during project export to facilitate seamless import into PIX4Dmatic.
    • Exporting and importing of RTK profiles.
    • Support for the Korean language.
    • Enhanced recommended NTRIP CRS selection with many improvements and fixes.
    • Fix connection issues with Trimble, Leica FLX100 RTK and BadElf RTK rovers.
    • Fix connection issue with AusCORS network when using Emlid RTK rover.
    • Fix issue of uploading to PIX4Dcloud without the selected output CRS.
    • Fix issue of removing the RTK profile after editing.
    • Fix issue of having the RTK card unresponsive when not receiving locations.
    • Fix issue of having the 3D Mesh not well placed in the detailed view.
    • General UI improvements & bug fixes.
    Technical notes:
    • Improved projects folder structure.
    Versions 2.14
     2.14.0 June 10, 2025 Updates, improvements and bug fixes.
    2.14.1 June 17, 2026 Updates, improvements and bug fixes.
     2.14.1
    • Support XTRS-NETRTK-MSM mountpoint for TOPCON HiPer CR RTK.
    • Add support page link when measuring offsets for TOPCON HiPer CR RTK.
    • Fix issue of not able to access premium features when auto-connecting to viDoc RTK.
    • Improve region of interest preview.
    2.14.0
    What’s new:
    • Support automatic selection for the NTRIP input CRS when creating RTK profiles.
    • Support and apply users access rights in organizations when exporting or uploading to PIX4Dcloud.
    • Auto connect to RTK when opening the app with an option in the settings to turn it ON or OFF.
    • Add camera offsets for Emlid and viDoc RTKs with iPhone 12, 13, 14, 15 and 16.
    • Allow PIX4Dcloud Gaussian Splatting option for projects without LiDAR and number of images less than 50.
    • Improve NTRIP connection.
    • Improve AR points and PIX4Dcloud AR positioning.
    • Improve Autotags detection stability.
    • Improve images geolocation.
    • Improve UI and warnings when pausing a capture.
    • Option to export logs from the settings.
    • Improved failures handling when connecting to RTK.
    • Fix login issues.
    • Fix viDoc RTK card status and disconnection issues.
    • Fix Trimble RTK connection issue.
    • Fix issues and crashes when creating and selecting RTK profiles.
    • Fix failure when uploading to PIX4Dcloud with GCPs and Autotags.
    • Fix issue of not having the 3D mesh well located.
    • Fix issue of not able to create GCP collection with geographic CRS.
    • Fix issue of changing the GCP collection input CRS when importing points.
    • Fix option to show/hide point labels in AR.
    • Fix issue of opening another project detailed view in multi-selection mode.
         Versions 2.13
    Version  Release Date  Release Type
     2.13.0  April 24, 2025  Updates, improvements and bug fixes.
    2.13.1 May 8, 20025  Updates, improvements and bug fixe.
     2.13.1
    What’s new:
    • Support MSM5 mountpoints for TOPCON HiPer CR RTK rover.
    • General improvements and fixes in the RTK connection dialog when connecting to Bluetooth and selecting NTRIP profiles.
    2.13.0
    What’s new:
    • Create an automatic Region of Interest and upload it to PIX4Dcloud.
    • Support new Geoids for Japan (JPGEO2024), Hungary (Geoid2014) and Greece (GR_HEPOS2011).
    • Support transformation from ETRS89 to GGRS87 for Greece.
    • Add TOPCON HiPer CR RTK diagram for custom camera offsets.
    • Add EXIF data to reference images taken for detailed annotations, save them as JPEG instead of PNG and rename them based on the corresponding annotation name.
    • Maintain same density for generated point cloud when optimising Autotags.
    • Improve processing results accuracy.
    • Improve upload failure handling.
    • Improve output CRS search.
    • Fix connection with some NTRIP services.
    • Fix issue of getting a failure when uploading a project to PIX4Dcloud with Autotags.
    • General UI fixes.
    Technical notes:
    • New region of interest folder is created with an OPF extension and a screenshot.
    Versions 2.12
    2.12.0 April 1 , 2025  Updates, improvements and bug fixes.
    2.12.1 April 9, 2025 Updates, improvements and bug fixes.
    2.12.1
    Bug fixes & Improvements:
    • Fix RTK RTCM transformations for Taiwan affecting PIX4Dcloud AR projects and AR points.
    • Fix RTK antenna offsets when RTK disconnects before saving the project.
    • Fix offsets shown in the UI after selecting an RTK case.
    • Fix issue of not showing the RTK profile in the connection panel if the clamp viDoc RTK was selected.
    • Show Casetify SPC+ case option for the recommended devices when selecting an RTK.
     2.12.0
    What’s new:
    • Support TOPCON HiPer CR RTK rover.
    • Add annotations from the project details and upload them to PIX4Dcloud.
    • Fix focal length for maximum resolution projects when sometimes it is not optimal.
      Version 2.11
    2.11.0 March 28, 2025  Updates, improvements and bug fixes.
    What’s new:
    • Improve RTK connection workflow
    • Create multiple RTK profiles with different RTK devices and NTRIP settings
    • Add automatic camera offsets for Leica FLX100 with its compatible handle and Quad Lock case.
    • Filter to show the recommended output CRS based on the user’s location or project’s location.
    • Filter for the projects list.
    • Option to generate and export dense point cloud.
    • Option in the advanced capture settings to remove the pause button.
    • Set a name, rename and delete computed volumes.
    • Support importing array of Korean Geoids for points measurements, for the "KVD1964 height" vertical coordinate system.
    • Optimize point cloud, mesh, RTK accuracies and cameras location on save.
    • Improve display of labels in the 3D view.
    • Improve app performance while capturing.
    • Improve permission requests handling.
    • Improve synchronization of uploaded projects.
    • Improve error messages.
    • Fix issue when refreshing the token for logged in users.
    • Fix issue of not showing the recover project dialog on app open.
    • Fix support link for the custom camera information button.
    Technical notes:
    • Add Xmp.Camera.RTKAccuracyThresholds to the images metadata.
    • Add photoUpdatedGeoFit logs to catchLog file each time camera locations are recomputed.
    • Add gpsUnreliabilityThreshold to gpsConfiguration log in CatchLog file.
    Versions 2.10
    2.10.0 February 17, 2025 Improvements and bug fixes.
    2.10.1 February 26, 2025 Improvements and bug fixes.
    2.10.2 March 6, 2025 Improvements and bug fixes.
    2.10.3 March 18, 2025 Improvements and bug fixes
    2.10.3
    • viDoc RTK improvements.
    2.10.2
    • Fix Refnet NTRIP connection issue.
    2.10.1
    • Improve app performance during capture.
    • Improve viDoc RTK connection stability.
    2.10.0
    What’s new:
    • Add tab bar to navigate between views.
    • Option to add and upload project records and keep them synchronized with PIX4Dcloud.
    • Improved view for the processing options in the upload dialog.
    • Improve Emlid Reach RX RTK accuracy when using custom camera offsets.
    • General UI improvements in the capture screen and the account dialog.
      Version 2.9
    2.9.0 February 10, 2025 Updates, improvements and bug fixes.
    What’s new:
    • Option to upload and process projects on PIX4Dcloud with Gaussian Splatting.
    • Show Autotags in the 3D view of the saving report and project details.
    • Fix optimal accuracy for RTK captures in the projects details.
    • Fix support links for custom offsets in the RTK connection dialog.
    • Fix offsets for viDoc RTK using iPad pro 11" with Casetify SPC+ case.
      Version 2.8
    2.8.0 January 23, 2025 Updates, improvements and bug fixes.
    What’s new:
    • Upload projects to PIX4Dcloud folders:
      • Create folders from PIX4Dcatch.
      • Handle and show permissions for Enterprise User Management (EUM) accounts.
    •  Display PIX4Dcloud projects with Autotags in AR (including indoor).
    • New upload dialog design.
    • Add accuracies for point collections created from autotags.
    • Improve camera parameters for recovered projects.
    • Fix issue of having the input CRS search bar case sensitive.
    • Fix issue of not having the viDoc rtkGPS file accuracies and statuses aligned.
    • Fix crash when changing orientation in the NTRIP mountpoint view.
    • Fix crash when presenting the project in live preview or 3D view.
    • Fix support link in the RTK custom offset Info icon.
    Version 2.7
    2.7.0 December 23, 2024 Improvements and bug fixes.
    What’s new:
    • Enhance saving computed volumes.
    • Improve viDoc connection stability.
    • Sort the NTRIP mountpoint based on the nearest one.
    • Add progress bar for Autotags optimization.
    • Fix crash when connecting to Trimble Catalyst DA2 RTK with invalid subscription.
    Version 2.6
    2.6.0 November 18, 2024 Updates, improvements and bug fixes.
    What’s new:
    • Add uncertainties map and legend for volume computation.
    • Ability to edit the points when selecting the volume computation area.
    • Add “What’s new” section in the account tab.
    • Show accuracy for Autotags in point collections.
    • Use cubic yards for US measurement system for volume computation.
    • Sort the input NTRIP CRS based on the user's location.
    • New sub layer tools menu in the detailed view.
    • Add support article link for volume computation in the help section.
    • Better failures handling for volume computation.
    • Fix connection issues with Leica FLX100 RTK rovers.
    • Fix issue of not triggering the processing when uploading projects to PIX4Dcloud.
      Version 2.5
    2.5.0 December 9, 2024 Updates, improvements and bug fixes.
    What’s new:
    • Support automatic RTK camera offsets for iPad Pro 11-inch/M4 and iPad Pro 13-inch/M4 with the Pix4D case (CASETiFY case with SPC+ connector).
    • Support automatic RTK camera offsets for iPhone 16 Pro and iPhone 16 Pro Max (with SPC+ case).
    • Support new Geoids for Austria (Austrian Geoid 2008 | GHA) and New Zealand (NZGeoid2016 | ...) .
    • Add a help section in the account dialog .
    • Support for Czech Republic language.
    • Enhance volume computation points selection and workflow.
    •  Enhance the RTKs connection errors handling.
    • Output coordinate reference system sorted by user's location or project's location.
    • Add a search bar for NTRIP mountpoints.
    • Fix issue of showing wrong state and color in the RTK connection panel.
    • Fix Trimble Catalyst DA2 RTK vertical height issue.
    • Fix NTRIP connection failure for TLS networks.
    • Fix canceling issue when using PIX4Dcloud AR and AR Points at the same time.
    • Fix Leica FLX100 RTK connection failures.
    • Fix issue of not able to click on the RTK connect button.
    • Fix export logs.
    • Fix issue of creating multiple redundant PIX4Dcloud datasets.
    Technical notes:
    • Fix issue of exported zip having a root directory with the project name.
    Version 2.4
    2.4.0 October 10, 2024 Bug fixes and improvements
    2.4.1 October 24, 2024 Bug fixes and improvements
    2.4.1
    Bug fixes and improvements:
    • Fix and improve the connection workflow for viDoc, Leica FLX100 and Trimble Catalyst DA2 RTK rovers.
    • Fix issue of not always having all files in the exported project zip.
    • Fix issue of not showing the Autotags on PIX4Dcloud.
    • Fix crash when expanding the RTK card in point management views.
    • Upgrade minimum iOS version supported to 17.0.
    2.4.0
    What’s new:
    • RTK panel is available in advanced and simplified modes.
    • Option in the account access manager to block project settings.
    • Fix connection issues for viDoc, Leica FLX100 and Trimble Catalyst DA2 RTK rovers.
    • Fix single point measurements CRS for Taiwan.
    • Fix RTK offsets unit conversion.
    • Fix crash when opening the project details tab.
    • Fix issue when changing the NTRIP credentials.
    • General UI fixes.
    Version 2.3
    2.3.0 September 23, 2024 Updates, improvements and bug fixes.
    2.3.1 September 26, 2024 Bug fixes
    2.3.1
    • Fix Leica FLX100 offset diagram.
    • Fix crash when opening the details view.
    • Fix UI issues.
    2.3.0
    What’s new:
    • Support for Bad Elf Flex RTK rover.
    • Support for Leica Zeno FLX100 plus RTK rover.
    • Handle support for Trimble Catalyst DA2 RTK rover.
    • Compute volumes and generate PDF reports.
    • Create point collection from detected autotags.
    • Settings to restrict capture only with RTK and lock the capture settings.
    • Improved RTK connection workflow.
    • Fix issue while uploading multiple projects to PIX4Dcloud.
    • Improved PIX4Dcloud AR projects handling.
    Technical notes:
    • When computing volumes a dense point cloud is generated in the "opf" folder inside the project directory, and overwrite the pcl.gltf file.
    • The volume PDF reports are saved in a “volume” folder inside the project directory.
      Version 2.2
    2.2.0 August 29, 2024 Updates, improvements and bug fixes.
    What’s new:
    • Option to optimize and rerun autotags detection after capture.
    • Option to recover crashed projects.
    • Option to import Korean Geoids for points measurements for the "KVD1964 height" vertical coordinate system.
    • Improve showing the annotations in PIX4Dcloud AR.
    • Improved handling of login failures.
    • Better handling of coordinate system transformation failures.
    • Show correct projects status when multiple projects are uploaded to PIX4Dcloud.
    • Fix issue of not able to disable AR Points.
    • Fix issue of having missing files after uploading a project to PIX4Dcloud.
    • Fix corrupted PLY files.
    • Fix crashes while capturing with autotags.
    • General bug fixes and UI improvements.
    Technical notes:
    • Recovering a project will create an opf folder in the project’s folder with the pointcloud (pcl.gltf) inside it. The captured point cloud pointcloud.gltf will not exist for this case.
         Version 2.1
    2.1.0 May 28, 2024 Updates, improvements and bug fixes
    2.1.1 July 8, 2024 Updates, improvements and bug fixes
    2.1.2 July 15, 2024 Bug Fixes
    2.1.3 July 25, 2024 Bug fixes
    2.1.4 August 12, 2024 Bug fixes
    2.1.5 August 18, 2024 Bug fixes
    2.1.0
    What’s new:
    • Export multiple projects.
    • Add 2 weeks trial period for PIX4Dcatch Professional license.
    • Trimble Catalyst DA2 enhancements.
    • Support geoids for Singapore (SGeoid09), Newfoundland (CGG2000/HTv2.0), Czech Republic (CR-2005), Portugal (GeodPT08), Corsica (RAC23) and Lithuanian (LIT20G).
    • Added section to redirect the user to the PIX4Dcatch online courses.
    • Show in-app notification when there is an app update.
    • Improvements for in-app purchase LIT.
    • Ability to cancel the projects upload and delete the projects from PIX4Dcloud.
    • Automatic skip of failed projects after several attempts for multi-upload.
    • Improved license error reporting.
    • Improved licenses handling for accounts with more than one license.
    • Improve autotags detection.
    • General bug fixes & UI improvements.
    2.1.1
    Bug fixes:
    • Fix in-app PIX4Dcatch Professional license subscription.
    2.1.2
    Bug fixes:
    • Fix crash in the RTK connection dialog when entering wrong NTRIP information.
    2.1.3
    Bug fixes:
    • General bug fixes.
    2.1.4
    Bug fixes:
    2.1.5
    Bug fixes:
    •  Fix NTRIP servers connection issue.
    Version 2.0
    Version
    Release date
    Release type
    2.0.0
    April 30, 2024
    Updates, improvements and bug fixes:
    What's new:
    • Support for Emlid Reach RX RTK rover.
    • Support for Trimble Catalyst DA2 RTK rover.
    • Display PIX4Dcloud projects in AR (Option available in the toolbox).
    • Detected Autotags will be used in the processing when uploaded to PIX4Dcloud.
    • Show Autotags in the saving report and the projects list.
    • In-app purchase for PIX4Dcatch Professional monthly license.
    Improvements:
    • Improve Autotags detection and memory usage.
    • Show a visual diagram for the viDoc RTK offset values.
    • Show device name and offsets when selecting SPC/SPC+ in the viDoc connection dialog.
    • Save the custom camera offsets entered by the user.
    • Save the upload processing options for the next upload.
    • Add low memory storage warning when starting the capture.
    Bug fixes:
    • Improve stability when uploading projects to PIX4Dcloud.
    • Fix crash due to low memory when saving big projects.
    Versions 1.31
    Version
    Release date
    Release type
    1.31.2
    March 26th, 2024
    Bug fixes
    1.31.1
    March 12th, 2024
    Bug fixes
    1.31.0
    March 4th, 2024
    Updates, Improvements, Bug fixes
    1.31.2
    Bug Fixes and improvements:
    • Improve stability when capturing & saving projects.
    • Improve upload projects to PIX4Dcloud.
    • General improvements.
    1.31.1
    Bug Fixes:
    • Fix NTRIP connection issue in Taiwan.
    • Fix issue of the sky not being filtered using iPhone 15.
    • General bug fixes & improvements.
    1.31.0
    What's new:
    • Select and upload multiple projects to PIX4Dcloud.
    • Improved detection of Auto Tags at greater distances.
    • Option to use detected Auto Tags to improve reconstructions.
    Improvements:
    • Improve app stability.
    • Add options for AR points in the settings.
    • AR Points guiding arrow for the nearest point.
    • Show the "bubble level" before starting the single point measurement.
    • Save report.pdf also for GPS projects.
    • UI improvements.
    Bug Fixes:
    • Fix issue of having corrupted GCP collections.
    • Fix crash when texturing the mesh in the detailed view.
    • Fix upload failure after deleting images of a resumed project.
    Versions 1.30
    Version
    Release date
    Release type
    1.30.3
    February 13th, 2024
    Bug fixes
    1.30.2
    February 5th, 2024
    Bug fixes
    1.30.1
    January 30th, 2024
    Bug fixes
    1.30.0
    January 25th, 2024
    1.30.3
    Bug fixes:
    •  Fix minor application bugs.
    1.30.2
    •  Fix wrong elevation when importing GCPs in feet.
    1.30.1
    • Fix issue of coordinate transformation not being applied for specific NTRIP mountpoints such as in Taiwan.
    • Correct LNO2 altitude values for mountpoints of the Swipos NTRIP service.
    • Fix issue of not getting corrected coordinates when reconnecting to viDoc.
    1.30.0
    What's new:
    • Display georeferenced points in AR.
    • Support SPC+ case for viDoc RTK.
    • Add new geoids for Argentina and Poland: GEOIDE-Ar16 and PL-geoid-2021.
    • Show the account and organization you belong to in the upload dialog.
    • Ability to set the output CRS when uploading a GPS project to PIX4Dcloud.
    • Better failures handling when uploading projects to PIX4Dcloud.
    • Improve images geolocation when using RTK.
    • Fix wrong offset values and GCPs height when using feet,
    • Fix issue of having corrupted depth files.
    Versions 1.29
    Version
    Release date
    Release type
    1.29.0
    November 27th, 2023
    What's new:
    •  Automatic Tag Detection of GCPs during capture using unique ID encoded Targets.
    •  Support of specific RTCM messages to handle correctly Taiwan CRS.
    •  Fix corrupted or missing depth images capturing high resolution or 4k.
    • Fix renaming and deleting GCP reference images.
    • Fix upload progression percentage.
    • Fix Site Localization map size.
    • Fix RTK NTRIP form editing.
    • Fix projects status when switching accounts.
    • Fix upload button to stay active during the upload.
    • Fix crash when saving Privacy Settings.
    • Improve importing of points.
    Versions 1.28
    Version
    Release date
    Release type
    1.28.1
    November 23th, 2023
    1.28.0
    October 13th, 2023
    1.28.1
    What's new
    • Fix missing geoids for Finland, Latvia and Taiwan (FIN2000, FIN2005N00, LV14, TWGEOID2018h).
    1.28.0
    What's new
    • Add German translation.
    • Add traditional Chinese translation.
    • Added new geoids for Finland, Latvia and Taiwan (FIN2000, FIN2005N00, LV14, TWGEOID2018h).
    • Fix project statuses after changing user account.
    • Improved upload to PIX4Dcloud to retry after a given time in case it fails.
    • UI improvements.
    Versions 1.27
    Version
    Release date
    Release type
    1.27.1
    September 27th, 2023
    1.27.0
    September 13th, 2023
    1.27.1
    • Fix antenna offsets issues with iPad Pro.
    1.27.0
    What's new
    • Added support for EUM.
    • viDoc antenna offsets can be defined manually.
    • Now available in French and simplified Chinese.
    • Fix issue with height conversion importing points.
    • Improved viDoc connection stability.
    • UI improvements.
    Version 1.26
    Version
    Release date
    Release type
    1.26.2
    August 24th, 2023
    Improvements
    1.26.1
    August 7th, 2023
    1.26.0
    August 2nd, 2023
    1.26.2
    What's new
    • Added support for German Geoid (GCG2016) and Slovenian geoid (SLO-VRP2016/Koper).
    1.26.1
    • Fix crash when running on iOS 15.
    1026.0
    What's new
    • Achieve increased accuracy by including GCPs when processing projects:
    • Import points as GCPs.
    • Easily mark GCPs in images.
    • Upload and process with marks to PIX4Dcloud or export them to use in PIX4Dmatic.
    • Now available in Spanish.
    • Save detailed info for point collections in one file available on export.
    • Improved mesh saving.
    • Importing a file from Google Drive doesn’t show an empty file.
    • UI improvements.
    Versions 1.25
    Version
    Release date
    Release type
    1.25.1
    July 4th, 2023
    1.25.0
    Jun 22th, 2023
    1.25.1
    • Improved viDoc accuracy.
    • Fixed viDoc antenna offset for single point measurement.
    • Fixed missing laser switch for single point measurement.
    1.25.0
    What's new
    • viDoc: Select satellite constellations.
    • Drag down to refresh cloud projects in projects view.
    • Japanese language support.
    • Quality report for RTK projects.
    • Support for new cloud features.
    • Improved point cloud.
    • Improved projects list loading time.
    • Fixed report sometimes not saving.
    • Updates for Japanese language.
    • General UI fixes and updates.
    Version 1.24
    Version
    Release date
    Release type
    1.24.0
    May 25th, 2023
    Improvements
    • Improve memory usage on recording some projects.
    • Improve point cloud and mesh saving, by default in GLTF format.
    • Save and display antenna height with 3 decimals.
    Bug fixes
    • Fix optimal accuracy text in project details.
    • Fix the antenna height reset when changing view.
    • Fix the reset of minimum elevation for satellite when selecting viDoc.
    Version 1.23
    Version
    Release date
    Release type
    1.23.0
    April 24th, 2023
    What's new
    • Indicate how many satellites are used with viDoc connection.
    Improvements
    • Show map in project details for iPhone in portrait view.
    • Images and measured points use ellipsoidal height when using the device GPS.
    • Improve NTRIP connection process.
    Bug fixes
    • Fix crash when turning on Show Overlap.
    • UI fixes and stability improvements.
    Version 1.22
    Version
    Release date
    Release type
    1.22.0
    April 5th, 2023
    What's new
    • Show a report with estimated accuracies at the end of capture and in the project detailed view.
    • Ability to set minimum elevation for satellites for the viDoc RTK rover antenna.
    Improvements
    • Improved refresh rate for viDoc RTK rover battery status.
    • Improved LiDAR point clouds alignment.
    • Improved Japanese translations.
    • viDoc RTK rover laser activation when connecting from the measurement settings view.
    Bug fixes
    • Live preview fixes and updates.
    • RTK information panel fixes for wrong N/A accuracies and status labels.
    • UI fixes and updates.
    Version 1.21
    Version
    Release date
    Release type
    1.21.0
    March 3rd, 2023
    What's new
    • viDoc support for iPad SP Connect case.
    Improvements
    • Geolocation view updates.
    Bug fixes
    • viDoc stability improvements.
    Version 1.20
    Version
    Release date
    Release type
    1.20.0
    February 28th, 2023
    What's new
    • Support for site localization:
      • Create a site localization point collection to compute and define a custom coordinate system.
      • Import local points with an arbitrary coordinate system or global points with a geographic coordinate system.
      • Link local and global points.
      • Process project on PIX4Dcloud with a site localization.
      • Export site localization WKT2 file.
      • Export local and global points from the site localization point collection in two separate CSV files.
    • Added Vietnamese CRS: VN2000 planimetry coordinate systems (EPSG: 5896 to 5899).
    Improvements
    • Improved accuracy for viDoc with iPad.
    • Improved accuracy for large captures with viDoc.
    • Improved support for viDoc with iPhone 14 Pro and iPhone 14 Pro Max.
    • Improved viDoc stability and NTRIP service connection.
    • Improved viDoc stability of laser measurement.
    • Improved workflow for account deletion.
    Bug fixes
    • Fixed crash when turning on the option “Show overlap” during a capture.
    Version 1.19
    Version
    Release date
    Release type
    1.19.0
    December 21st, 2022
    What's new
    • Added the Israeli coordinate system (EPSG: 6991 - Israeli Grid 05).
    • Added several Vietnamese coordinate systems (EPSG: 9205 to 9218).
    Improvements
    • Improved Japanese translation.
    • Minor improvements to the user interface.
    Bug fixes
    • Fixed project browser view on iPhone.
    Version 1.18
    Version
    Release date
    Release type
    1.18.0
    October 31st, 2022
    What's new
    • Ability to enter geoid height.
    • Added geoids: 'CGG2013a', 'arcgp-2006-sk'.
    • Added “SVD2006 height”, “CGVD2013a(2002) height” and “CGVD2013a(1997) height” vertical coordinate reference systems.
    Improvements
    • Improve stability for large captures.
    Bug fixes
    • Fix decimal keypads not working with localized separators.
    • Small bug fixes.
    Version 1.17
    Version
    Release date
    Release type
    1.17.0
    October 11th, 2022
    What's new
    • Ability to select camera resolution for capture from iOS 16.
    • Added geoids: 'RAF20', 'RAF18b', 'hBG18', 'OSGM15'
    • Available in the Japanese language.
    Improvements
    • Improve axis and unit definitions for GCP.
    • Improved warnings during capture.
    Bug fixes
    • Fix the black cameras when adding GCP reference images.
    Version 1.16
    Version
    Release date
    Release type
    1.16.0
    September 9th, 2022
    Improvements
    • Warning messages for GCP (Ground Control Point) measurements.
    • Improved viDoc Bluetooth connection stability.
    Bug fixes
    • Fixed instances when the first project image was not well located.
    Version 1.15
    Version
    Release date
    Release type
    1.15.0
    August 9th, 2022
    What's new
    • Added the “PL-geoid-2011” geoid
    Improvements
    • Improved CRS selection for GCPs and Uploads.
    • Improved reliability and performance for large captures.
    • General fixes and UI improvements to GCP management.
    • Improved viDoc bluetooth connection stability.
    • Improved storing and retrieval of NTRIP credentials.
    • Improved triggering when capturing far away scenes.
    Bug fixes
    • Fix an issue with authentication flow to PIX4Dcloud.
    • Fix some issues capturing a project.
    • Many UI updates and fixes.
    Version 1.14
    Version
    Release date
    Release type
    1.14.0
    July 6th, 2022
    What's new
    • Ability to capture and add reference images when measuring GCPs.
    Improvements
    • Warning if a project failed to save correctly.
    • Small bug fixes and UI improvements.
    Version 1.13
    Version
    Release date
    Release type
    1.13.0
    May 19th, 2022
    What's new
    • Audible warnings during capture.
    Improvements
    • Improved image triggering.
    • Improved connection dialog to viDoc RTK rover.
    • Improved authentication flow.
    Version 1.12
    Version
    Release date
    Release type
    1.12.0
    March 23rd, 2022
    What's new
    • Set output coordinate reference system for measured GCPs.
    • Show GCP coordinates in the output coordinate reference system.
    Improvements
    • Improved connection dialog with viDoc RTK rover.
    • Improved warning and error reporting.
    • Improved login and signup.
    Version 1.11
    Version
    Release date
    Release type
    1.11.0
    February 10th, 2022
    What's new
    • Show battery indicator for viDoc.
    • Compatibility with iPhone 13 Pro and iPhone 13 Pro Max.
    • Improved accuracy of altitude measurement with laser.
    • HDOP values are saved with single-point measurements.
    • Allow imperial measurements for antenna offset.
    • New geoids are available.
    Improvements
    • Show third-party licenses.
    • Allow single-point measurement even if high accuracy cannot be achieved.
    Bug fixes
    • Fixed slow loading and possible crash of the project's view.
    Version 1.10
    Version
    Release date
    Release type
    1.10.0
    December 20th, 2021
    What's new
    • Enable laser functionality of the viDoc RTK rover for single-point measurement.
    • Added Swiss and Norwegian Geoids.
    • App usage disclaimer.
    Improvements
    • Option to delete GCP measurements.
    Version 1.9
    Version
    Release date
    Release type
    1.9.0
    November 29th, 2021
    What's new
    • New PIX4Dcloud processing pipeline is now set as default.
    • Support for 2D maps and volume measurement.
    • LiDAR data will be used if available.
    • Option to generate 2D maps when processing with LiDAR data.
    • Ability to cancel a capture without saving.
    Improvements
    • Improved project naming/renaming.
    • Fix for incorrect EXIF data when using iOS 15.0.
    Version 1.8
    Version
    Release date
    Release type
    1.8.0
    November 4th, 2021
    What's new
    • Single Point Measurement.
    • Record single points using viDoc RTK rover or GNSS.
    • Export points in a .csv file format that is compatible with PIX4Dmatic.
    • Rename project on save.
    • Added NAVD88 ftUS vertical coordinate system.
    • New minimum iOS version is iOS 14.1.
    Improvements
    • Improve yaw orientation of reconstructions when there is a good GNSS signal.
    • Improved map display in details view.
    Version 1.7
    Version
    Release date
    Release type
    1.7.0
    October 4th, 2021
    What's new
    • Image trigger improvements.
    Version 1.6
    Version
    Release date
    Release type
    1.6.0
    September 14th, 2021
    Updates
    What's new
    • The LiDAR mesh can be viewed and exported from the project details.
                                                      Version 1.5
    Version
    Release date
    Release type
    1.5.0
    August 25th, 2021
    What's new
    • Project Details Views.
    • Inspect individual images.
    • Embedded web view to show processed project results.
    • Updated UI.
    • viDoc will attempt to auto-connect on app startup.
    Improvements
    • Upload progress is shown as a percentage.
    • Improved calculation of altitude when using viDoc.
    Version 1.4
    Version
    Release date
    Release type
    1.4.0
    August 4th, 2021
    What's new
    • Live-preview.
      • Show 3D preview of the scene captured in real-time.
      • Show the location of images in the live preview.
      • Toggle between top view and synchronized camera views.
    • Visualize & export the 3D model.
    • 3D view in the project details that renders the depth points & the images.
    • Export the point cloud in PLY format.
    • Option to set the vertical coordinate system and geoid when using viDoc RTK.
    Improvements
    • Fixed the orientation for images taken with the iPhone in portrait mode.
    • Improved reconstruction orientation for viDoc RTK projects with low accuracy.
    • Improved stability when saving RTK captures.
    • Improved upload to cloud and export.
    Versions 1.3
    Version
    Release date
    Release type
    1.3.1
    July 6th, 2021
    1.3.0
    April 29th, 2021
    1.3.1
    What's new
    • Ability to define the horizontal input Coordinate System while using the viDoc RTK rover.
    • Ability to define the horizontal output Coordinate System before upload to PIX4Dcloud while using the viDoc RTK rover.
    • Display RTK connection status and HDOP value indicating the quality of RTK connectivity during capture using the viDoc RTK rover.
    • Improved Bluetooth connection stability.
    • Automatic removal of sky from the 3D models when the project is uploaded to PIX4Dcloud (only enabled when LiDAR scanner data is enabled).
    • Generation of the quality report when LiDAR scanner data is enabled when uploading to PIX4DcloudSupport for viDoc RTK.
    Improvements
    • Fixed issues with connections to various NTRIP providers while using the viDoc RTK rover for PIX4Dcatch.
    • Improved stability of upload to PIX4Dcloud.
    1.3.0
    What's new
    • Support for viDoc RTK.
    • Add ability to share logs.
    • Default trigger set to 90% overlap.
    Improvements
    • Automatically create a trial if one is available.
    • Export projects over 4GB.
    Versions 1.2
    Version
    Release date
    Release type
    1.2.3
    March 16th, 2022
    1.2.2
    February 10th, 2021
    1.2.1
    January 13th, 2021
    1.2.0
    January 4th, 2021
    1.2.3
    What's new
    • Portrait mode now available for iPhone.
    • Access to manage user account from the capture screen.
    Bugs fixes
    • Fix for corrupted ZIP file blocking export.
    • Fix volume computation in PIX4Dcloud for projects that have a sub-mm GSD.
    • Improved handling of project upload to PIX4Dcloud.
    1.2.2
    What's new
    • The capture experience has been improved by replacing the default purple 3D mesh with a wireframe to give unobstructed views to the real world. The settings need to be reset to default to incorporate this change.
    • Volume measurements and Digital Surface Model (DSM) enabled in PIX4Dcloud when processing with depth.
    • The geolocation accuracy of the 3D scan is shown within the project's details.
    Bugs fixes
    • Fixes export to Files app and external hard drives.
    1.2.1
    What's new
    • Exporting now zips all data into a single file for easier sharing with third-party services.
    Bugs fixes
    • Fixes on occasional crashes when saving a project.
    1.2.0
    What's new
    • Option to process with depth information for devices with a LiDAR sensor.
    • Option to generate DSM and Orthomosaic.
    • Captured image locations are shown on the map.
    • Bug fixes and improvements.
    Version 1.1
    Version
    Release date
    Release type
    1.1.1
    November 5th, 2020
    What's new
    • Filter and search projects.
    • Multi select and delete.
    • Project Details.
    • Updates and Improvements to the UI.
    • Cloud Updates
      • Uploads to PIX4Dcloud now generate DSM models by default to enable volume.
    Improvements
    • Enable upload for PIX4Dmapper licenses that have cloud allowance.
    • Fix issue with iPhone 12 Pro not triggering enough images.
    • Use flat shading for the LiDAR mesh.
    • Option to texture the mesh.
    Versions 1.0
    Version
    Release date
    Release type
    1.0.3
    August 12th, 2020
    Updates
    1.0.2
    July 4th, 2020
    Bug fixes
    1.0.1
    June 22nd, 2020
    Bug fixes
    1.0.0
    June 12th, 2020
    Initial release
    1.0.3
    What's new
    • New upload dialog.
    • Shows cloud allowance.
    • Allows upload to Sites.
    • Add Make and Model to image EXIF.
    1.0.2
    Bug fixes
    • Fix issue with license not detected.
    • Minor bug fixes.
    1.0.1
    Bugs fixes
    • Fix occasional crash when saving or updating images.
    Other
    • Better feedback for cloud upload.
    • UI Improvements.
    • Reliability improvements.
    1.0.0
    PIX4Dcatch is the tool for acquiring optimal ground images for photogrammetry. These ground images can be used to get highly accurate 3D models on PIX4Dcloud or offline within PIX4Dmapper.
    No need to be an expert. Walk around your area of interest and the app will record pictures along the way, together with GPS positions. Using augmented reality, get live feedback on the covered area and the completeness of the scan thanks to the overlaid 3D mesh on the current video frame that is available for devices with LiDAR sensors.
    Images can be uploaded to PIX4Dcloud for a fast generation of scaled and georeferenced 3D models and point clouds, that you can visualize, measure, share, and export. Or they can be exported locally for processing in PIX4Dmapper.
    Workflow
    • Scan: Walk around the area of interest. PIX4Dcatch automatically records geotagged frames and displays on your screen real-time 3D meshing for scene completion feedback.
    • Upload: Stop recording and automatically upload images to PIX4Dcloud to generate accurate and easy to share 3D models.
    • Export: transfer the images from your device to your desktop computer and start the photogrammetry process, add GCPs, and validate the accuracy of your 3D scene.
    • Examine: Measure distances, areas, and volumes, and perform virtual inspections.
    • Share: Selectively and securely share project data and insights with your team, clients, and suppliers.
    Device compatibility:
    • Optimized for LiDAR equipped devices.
    • ARKit enabled devices.
    Usage information
    • Ensure the app is up to date. Upload the images to PIX4Dcloud to generate, visualize, measure, and share your 3D model.
    • PIX4D accepts no liability for damage, injuries, or legalities from the misuse of this app. Use only in safe environments.
