(iOS) Pix4Dcatch technical release notes
Download the latest version for iOS.
Current version 1.3.0
1.3.0 Apr 29th, 2021 Updates, Improvements
Version 1.3.0
What's new
  • Support for viDoc RTK
  • Add ability to share logs
  • Default trigger set to 90% overlap
Improvements
  • Automatically create a trial if one is available
  • Export projects over 4GB
Versions 1.2.0
1.2.3 Mar 16th, 2022 Updates, Improvements
1.2.2 Feb 10th, 2021 Updates, Improvements
1.2.1 Jan 13th, 2021 Updates, Improvements
1.2.0 Jan 4th, 2021 Updates, Improvements
Version 1.2.3
What's new
  • Portrait mode now available for iPhone
  • Access to manage user account from the capture screen
Bugs fixes
  • Fix for corrupted ZIP file blocking export
  • Fix volume computation in Pix4Dcloud for projects that have a sub-mm GSD
  • Improved handling of project upload to Pix4Dcloud
Version 1.2.2
What's new
  • The capture experience has been improved by replacing the default purple 3D mesh with a wireframe to give unobstructed views to the real world. The settings need to be reset to default to incorporate this change
  • Volume measurements and Digital Surface Model (DSM) enabled in Pix4Dcloud when processing with depth.
  • The geolocation accuracy of the 3D scan is shown within the project's details
Bugs fixes
  • Fixes export to Files app and external hard drives
  • Minor improvements to the user interface
Version 1.2.1
What's new
  • Exporting now zips all data into a single file for easier sharing with third-party services
Bugs fixes
  • Fixes on occasional crashes when saving a project
Version 1.2.0
What's new
  • Option to process with depth information for devices with a LiDAR sensor
  • Option to generate DSM and Orthomosaic
  • Captured image locations are shown on the map
  • Bug fixes and improvements
Versions 1.1.0
1.1.1 Nov 5th, 2020 Updates, Improvements
Version 1.1.1
What's new
  • Filter and search projects
  • Multi select and delete
  • Project Details
  • Updates and Improvements to the UI
Cloud Updates
  • Uploads to Pix4Dcloud now generate DSM models by default to enable volume
Improvements
  • Enable upload for Pix4Dmapper licenses that have cloud allowance
  • Fix issue with iPhone 12 Pro not triggering enough images
  • Use flat shading for the LiDAR mesh
  • Option to texture the mesh
Versions 1.0.0
1.0.3 Aug 12th, 2020 Updates
1.0.2 July 4th, 2020 Bug fixes
1.0.1 June 22nd, 2020 Bug fixes
1.0.0 June 12th, 2020 Initial release
Version 1.0.3
Updates
  • New upload dialog.
  • Shows cloud allowance.
  • Allows upload to Sites.
  • Add Make and Model to image EXIF
Version 1.0.2
Bug fixes
  • Fix issue with license not detected.
  • Minor bug fixes.
Version 1.0.1
Bugs fixes
  • Fix occasional crash when saving or updating images.
 Other
  • Better feedback for cloud upload.
  • UI Improvements.
  • Reliability improvements.
Version 1.0.0
Pix4Dcatch is the tool for acquiring optimal ground images for photogrammetry. These ground images can be used to get highly accurate 3D models on Pix4Dcloud or offline within Pix4Dmapper.
No need to be an expert. Walk around your area of interest and the app will record pictures along the way, together with GPS positions. Using augmented reality, get live feedback on the covered area and the completeness of the scan thanks to the overlaid 3D mesh on the current video frame that is available for devices with LiDAR sensors.
Images can be uploaded to Pix4Dcloud for a fast generation of scaled and georeferenced 3D models and point clouds, that you can visualize, measure, share, and export. Or they can be exported locally for processing in Pix4Dmapper.
Workflow
  1.  Scan: Walk around the area of interest. Pix4Dcatch automatically records geotagged frames and displays on your screen real-time 3D meshing for scene completion feedback.
  2. Upload: Stop recording and automatically upload images to Pix4Dcloud to generate accurate and easy to share 3D models.
  3. Export: transfer the images from your device to your desktop computer and start the photogrammetry process, add GCPs, and validate the accuracy of your 3D scene.
  4. Examine: Measure distances, areas, and volumes, and perform virtual inspections.
  5. Share: Selectively and securely share project data and insights with your team, clients, and suppliers. Devices compatibility:
Device compatibility:
  • Optimized for LiDAR equipped devices.
  • ARKit enabled devices.
Usage information
  • Ensure the app is up to date. Upload the images to Pix4Dcloud to generate, visualize, measure, and share your 3D model.
  • Pix4D accepts no liability for damage, injuries, or legalities from the misuse of this app. Use only in safe environments.
0 out of 0 found this helpful
