Calibrate
It allows users to change the following processing options:
- Calibration templates: Defines a default set of processing options.
- Calibration pipeline: Allows to select how the camera's internal and external parameters are optimized.
- Image scale: Defines the image size used to extract keypoints.
- Keypoints: Sets up the number of extracted keypoints.
- Use depth maps (Optional): To use depth maps generated by PIX4Dcatch.
- Internals confidence: To set the confidence of the initial camera calibration parameters.
- Reoptimize cameras: Fast reprocess the project after applying changes to Ground Control Points (GCPs).
These are the default calibration templates available in PIX4Dmatic. We strongly recommend using these to process your project:
Calibration Template | Description |
Large scale and corridor (Default) |
Calibration pipeline: Scalable standard. Typical input: Nadir images. Processing speed: Faster. Application: Generate 2D and 3D reconstructions of a relatively large area of interest with images captured above the area of interest. |
Map |
Calibration pipeline: Standard. Typical input: Nadir images. Processing speed: Slower. Application: Generate 2D and 3D reconstructions of an area of interest with images captured above the area of interest. |
Model |
Calibration pipeline: Standard. Typical input: Oblique images. Processing speed: Slower. Application: Generate 3D reconstructions of an object of interest with images captured around the object of interest. |
Flat scene and low texture |
Calibration pipeline: Low texture planar. Typical input: Nadir images. Processing speed: Slower. Application: Generate 2D and 3D reconstructions or an area of interest that contains relatively homogenous textures and relatively flat terrain, like an agricultural field, with images captured above the area of interest. |
PIX4Dcatch |
Calibration pipeline: Trusted location and orientation. Typical input: Terrestrial imagery. Processing speed: Faster. Application: Generate 2D and 3D reconstructions or an area or object of interest with images captured around the area or object of interest with PIX4Dcatch. |
Allows selecting how the camera's internal and external parameters are optimized.
- Scalable Standard (default): This calibration pipeline is a sequential pipeline that enhances image calibration for large datasets and fast processing.
- Standard: This calibration pipeline is similar to Scalable Standard, but it is more robust, requires more processing time, and uses more PC resources.
- Trusted location and orientation: This calibration pipeline is intended for projects with accurate relative location and IMU data; for example, images taken with PIX4Dcatch in an indoor or outdoor setting or images from RTK or PPK drones or devices. All images must include information about the camera's initial position and orientation.
- Low texture planar: The calibration pipeline is intended for aerial nadir images with accurate geolocation and homogeneous or repetitive content of relatively flat terrain.
Image scale
Defines the image size at which keypoints are extracted. It is possible to select:
- 1 (Original image scale): This is the recommended Image scale.
- 1/2 (Half image scale): This can be used to speed up processing and for cameras with very high resolution.
- 1/4 (Quarter image scale): This can be used to speed up processing to get a fast overview and assess the completeness of the project.
- 1/8 (Eighth image scale): This can be used to speed up processing to get a fast overview and assess the completeness of the project.
Keypoints
Allows to set up the number of extracted keypoints.
- Auto (Default): PIX4Dmatic automatically determines the optimal number of keypoints to extract.
- Custom: Directs PIX4Dmatic to identify a specific number of keypoints, image content permitting.
- Number of Keypoints: The targeted number of keypoints to be extracted per image.
Defines how much the camera parameters (internals) can be recalculated and adjusted during the project calibration:
- Low (Default): Optimizes all the internal camera parameters.
- High: Forces the internal parameters to be close to the initial values. We recommend using it when:
- The difference between the initial and optimized camera parameters is higher than 5%.
- The calibrated project is warped or curved.
Use depth maps: When enabled, the depth maps generated with PIX4Dcatch are used for better calibration.
Reoptimize cameras
This process is used to reoptimize already computed internal and external camera parameters. It can be used when changes to GCPs are applied after the Calibrate step is completed.
Such changes can be:
- Adding GCPs marks.
- Changing the position of existing GCPs marks.
- Removing GCPs with marks.
